Canon LBP6030 Mono Laser Printer
Quicklinx: 9T8JWS00 Mfr#: 8468B021
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
An affordable, space saving mono laser printer designed for personal or small office use. Quiet, reliable and highly energy efficient with low power consumption it delivers fast, high quality prints.
  • Space saving, mono laser printer
    Designed to fit comfortably on the desk, this fast, compact and affordable mono laser printer is perfect for personal and small office use. Its sleek, space-saving design includes a retractable paper tray cover.
  • Fast, productive performance
    The i-SENSYS LBP6030 springs into the action the moment you need it thanks to Canon’s Quick First-Print technologies, which ensure quick recovery from sleep mode. With a First Print Out Time (FPOT) of just 7.8 seconds and professional laser print speeds of 18 ppm there’s no waiting around for your prints - so you can quickly get back to what’s important.
  • Exceptional laser quality
    Enjoy the sharpest, crispest text and most detailed graphics thanks to high print resolution with Automatic Image Refinement. The MS (Magnetic Spherical) Toner has been specifically developed to deliver optimum results print after print.
  • Energy efficient
    Thanks to Canon’s On Demand fixing technology this energy efficient printer uses only 0.8 watts in sleep mode and there’s virtually no warm up time. A convenient front power switch makes it easy to turn off, cutting energy costs and reducing its environmental impact even further.
  • Quiet operation
    Thanks to Canon’s engine design, the i-SENSYS LBP6030 is silent in standby mode and exceptionally quiet during operation - so you can focus on your work without distraction.
  • All-in-One cartridge
    The recyclable All-in-One cartridge ensures maintenance-free operation and reliable high quality output. The Authentic Canon Laser Cartridge contains toner, drum and cleaning units and can be replaced in seconds without any fuss or mess.
Canon i-SENSYS LBP6030 - printer - B/W - laser
Printer Type
Personal printer - laser - B/W
5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 188 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 18 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
2400 x 600 dpi
Image Enhancement Technology
USB 2.0
RAM Installed (Max)
32 MB
Language Simulation
Canon Ultra Fast Rendering (UFRII LT)
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper
Total Media Capacity
150 sheets
Media Handling
150-sheet multipurpose tray
Monthly Duty Cycle (max)
5000 pages
Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition
36.4 cm x 24.9 cm x 19.9 cm
Printer Type
Personal printer - laser - monochrome
Printer
Print Speed
Wired
USB 2.0
2400 x 600 dpi
First Print Out Time B/W
7.8 sec
Language Simulation
Media Handling
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 188 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 188 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
100 sheets
Duty Cycle
5000 pages
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 - Canon 725 Starter
Power supply - internal
Frequency Required
50/60 Hz
870 Watt
Power Consumption Stand by
1.8 Watt
Power Consumption Sleep
0.8 Watt
Environmental Standards
ENERGY STAR
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
49.2 dBA
36.4 cm
24.9 cm
19.9 cm
5 kg
