Canon LBP252dw A4 Mono Laser Printer
Quicklinx: CBB3WS00 Mfr#: 0281C020
This compact and reliable A4 B&W laser printer boasts Adobe PostScript support for fast, high-quality results, plus a great choice of cloud and connectivity options for today's mobile devices.
Key Features
  • Compact, reliable A4 B&W laser printer for small workgroups and businesses.
  • Rapid, high quality 33 ppm printing helps keep your teams productive.
  • Ideal for frequent print tasks like forms, invoices, receipts and delivery notes.
  • Adobe PostScript support for easy network integration.
  • Consistent reliability and quality via Canon All-in-One replacement cartridges.
  • Free Canon app to work on the go with your Apple and Android devices.
  • Protect confidential documents via PIN code even when printing remotely.
  • Powerful connectivity including Apple AirPrint™ and Google Cloud Print.
  • Energy saving features like Auto Shutdown help keep your business sustainable.
  • Easy to monitor and update remotely via a web browser.
Get started with high quality workgroup printing
Small businesses and workgroup teams can easily achieve great results with this well equipped A4 B&W laser printer. The i-SENSYS LBP252dw's compact size and smart looks are ideal in customer-facing environments or busy offices. And you'll complete everyday tasks faster with rapid 33 ppm output and the ability to start printing from idle or standby in just a few seconds.
Sustained quality, easy ownership
Consistent reliability and renewed quality are ensured every time you change your toner thanks to Canon's easy-to-replace All-in-One cartridge design. Want your printer to run longer with fewer interventions? Choose the longer-lasting high yield cartridges. Even better, with just a single cartridge to keep track of, you'll have fewer items to order and manage, reducing your admin workload.
Great support for mobile and cloud
Do you and your teams enjoy the flexibility of moving seamlessly between locations and devices? Then the LBP252dw is ideal for you. No matter how or where you choose to work, your LBP252dw is always ready and accessible. Print from your iPhone or iPad via Apple AirPrint, or your Android device using Google Cloud Print, regardless of whether you're inside or outside the office.
Protecting your information and your bottom line
Concerned about document confidentiality in the office? Enjoy peace of mind using the Secure Print Function that enables you to securely print private and confidential documents using a PIN code. The LBP252dw protects your profitability too, with features like double-sided printing that reduce wasted paper, and Auto Shutdown that conserves electricity when your printer's not in use.
Network and integration-ready on-board Wi-Fi
The LBP252dw offers sophisticated capabilities for integrating seamlessly with IT networks. Support for PCL5e/6 and Adobe PostScript makes it an ideal choice for managed environments; while the Remote User Interface saves valuable time because IT Managers can monitor and update settings without making a site visit. And with Wi-Fi and Ethernet connectivity as standard, the LBP252dw has all the features you need to keep pace with your growing business.
  • Get started with high-quality workgroup printing
    Small businesses and workgroup teams can easily achieve great results with this well-equipped A4 laser printer. The i-SENSYS LBP252dw's compact size and smart looks are ideal in customer-facing environments or busy offices.
  • Sustained quality, easy ownership
    Consistent reliability and renewed quality are ensured every time you change your toner thanks to Canon's easy-to-replace cartridge design. Want your printer to run longer with fewer interventions? Choose the longer-lasting high yield cartridges.
  • Great support for mobile and cloud
  • Protecting your information and your bottom line
    Concerned about document confidentiality in the office? Enjoy peace of mind using the secure print function that enables you to securely print private and confidential documents using a PIN code.
Canon i-SENSYS LBP252dw - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
12.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 33 ppm - B/W - A4 (210 x 297 mm) , Up to 16.8 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
525 MHz
Language Simulation
PCL 5E, PostScript, PCL 6, Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, labels, plain paper, index cards, heavy-weight paper, recycled paper, postcards
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 3000 pages
Print server
AC 230V
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
40 cm x 37.7 cm x 29.8 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6 sec
Language Simulation
Fonts Included
45 x PCL , 136 x PostScript
Media Handling
525 MHz
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
750 - 3000 pages
Print server
Security Protocols & Features
Secure Print, Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 2100 pages - Canon 719
ISO/IEC 19752, ISO 9296
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1150 Watt
Power Consumption Stand by
12.1 Watt
Power Consumption Sleep
1 Watt
Software Included
Drivers & Utilities
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
53 dB
40 cm
37.7 cm
29.8 cm
12.4 kg
CBB3 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
CBB3 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
CBB3 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.04
CBB3 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.40
