Canon L140 Laser Fax Machine
Quicklinx: 4Z3MWS00 Mfr#: 2234B043
Get professional laser fax quality in a compact and stylish design with this affordable Super G3 fax. Easy to use and energy efficient, it's the ideal solution for small and medium-sized businesses.
Canon i-SENSYS FAX-L140 - fax / copier - B/W
Fax / copier
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 12 ppm
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR
Original Size
105 x 148 mm (min) - 210 x 400 mm (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Type
Plain paper
Standard Media Capacity
150 sheets
AC 230 V (50/60Hz)
40 cm x 38.6 cm x 22.1 cm
8 kg
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified
Fax / copier
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
2 lines x 20 characters
Copying
Max Copying Speed
Up to 12 ppm
Grayscale Half-Tones
256
Max Document Enlargement
200%
Max Document Reduction
50%
Maximum Copies
99
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR
Transmission Memory Capacity
Up to 340 pages
Fax Printing Speed
Up to 12 ppm
Fax Printing Resolution
600 x 600 dpi
Handset
Optional
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
15 station(s)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Broadcast Transmission
131 stations
Delayed Transmission
50 stations
Remote Fax Retrieval (Polling)
Activity report, transmit verification report, automatic redialing, smoothing, answering machine interface, dual-line fax capability
Document & Media Handling
Min Original Size
105 x 148 mm
Max Original Size
210 x 400 mm
Original Type
Sheets
30 sheets
Supported Media Type
Plain paper
150 sheets
ADF - 30 sheets size: 105 x 148 mm - 210 x 400 mm , Input tray - 150 sheets
AC 230 V (50/60Hz)
700 Watt
Power Consumption Standby
8 Watt
Power Consumption Sleep
3 Watt
Consumables Included
1 x toner cartridge - up to 2000 pages - Canon FX-10
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
40 cm
38.6 cm
22.1 cm
8 kg
Sound Emission
25 dBA (idle) / 66.7 dBA (operating)
4Z3M Canon FX10 BLACK TONER CARTRIDGE L100/L120 0263B002 L160 L12 In Stock £51.88
