Product
Canon IXUS 285 HS Black Camera Kit inc 16GB SD Card and Case
Quicklinx: BWSKWS00 Mfr#: 1076C007AA & 16GB CASE
Resolution: 20.2Megapixel
Optical Zoom: 12
Colour: Black
£163.29 ex VAT
£195.94 inc VAT
Put style and performance in your pocket with this slim 12x zoom IXUS. Shoot stunning photos and Full HD movies with ease and share effortlessly via Wi-Fi and NFC.
  • Pocketable style
    This ultra-slim and stylish metal-bodied IXUS is easy to carry with you wherever you go and features a flexible 25mm ultra-wide 12x optical zoom lens with 24x ZoomPlus; so you can easily capture every moment, near or far, in superb quality photos and movies. Auto Zoom helps you select the best framing at the touch of a button.
  • Instant Full HD movies
    Making great movies is fun and easy. With one touch of a button you can effortlessly shoot great Full HD movies (1080p) in MP4 format. Experience the creative versatility of shooting movies using the optical zoom and still enjoy sharp, steady results thanks to the Dynamic Image Stabilizer.
  • Quick connections
    Connect to your compatible smart device with just one tap using Wi-Fi with Dynamic NFC for easy sharing. Use Image Sync to automatically back-up new images to cloud services and capture great group shots with wireless Remote Shooting from your smart device. The Wi-Fi Button offers a quick and easy shortcut to Wi-Fi functions.
  • Superb quality
    Enjoy exceptional quality, detailed images - even in low light - thanks to a 20.2 Megapixels CMOS sensor and DIGIC 4+ processing. An intelligent optical Image Stabilizer ensures sharp stills and steady movies in any situation, while the large 7.5 cm (3.0") LCD screen allows easy shooting and playback.
  • Effortless creativity
    At the touch of the shutter, Creative Shot automatically analyzes the scene and creates 5 additional unique images of your original shot. Get close and capture stunning everyday detail with 1 cm Macro or simply point and shoot with Hybrid Auto and let the camera automatically create a fun HD (720p) movie summary of the day.
Canon IXUS 285 HS - digital camera
Digital camera - 1080p - compact
Memory Card Slot
SD card
Image Processor
DIGIC 4+
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
20.2 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 12x zoom - 4.5 - 54 mm - f/3.6-7.0
Focus Adjustment
Automatic
Digital Zoom
4x
Image Stabiliser
Optical (Intelligent IS with 4-axis Enhanced Dynamic Mode)
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
1 x Canon NB-11L Li-ion rechargeable battery - 680 mAh (optional) , 1 x Canon NB-11LH Li-ion rechargeable battery - 800 mAh (included)
Composite video/audio, HDMI, USB 2.0
9.96 cm x 2.28 cm x 5.8 cm
147 g
Enclosure Colour
Sensor Resolution
20.2 Megapixel
Optical Sensor Type
BSI-CMOS
Total Pixels
21,100,000 pixels
Effective Sensor Resolution
20,200,000 pixels
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
30 fps
ISO (Max)
3200
Optical Zoom
12x
Digital Zoom
4x
Image Processor
DIGIC 4+
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
9
AE/AF Control
Face-priority AF, Subject-tracking AF, AI Focus AF
Face Detection
Face Detection AF/AE/FE/WB, Face Detection Self-timer, Wink Self-timer, Smile Shutter
Digital Video Format
H.264
Image Recording Format
JPEG
1920 x 1080
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Computer Connectivity
Mac, Windows
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto
Exposure Metering
Evaluative, centre-weighted, spot
Exposure Modes
Programme, automatic
Shooting Programs
Portrait mode, slow shutter, fireworks, low light, hi-speed burst, smart shutter, handheld night scene
Special Effects
Black & White, Sepia, Neutral, Vivid, Custom Effect, fisheye, monochrome, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, miniature, Positive Film, Toy camera, Posterisation, Super Vivid
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
15 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
25 - 300mm
Focus Adjustment
Automatic
Macro Focus Range
1cm
Zoom Adjustment
Motorised drive
Lens Construction
7 groups / 9 elements
Built-in lens shield, aspherical lens, UA lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.5 m - 4 m (wide lens) , 1 m - 2 m (tele lens)
Additional Features
Continuous Shooting Speed
2.5 frames per second, 7.2 frames per second (5MP)
Self-Timer Delay
10 sec, 2sec
Additional Features
Digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, resizing an image, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, face detection, Smart Flash Exposure, HS System, Smart AUTO, primary colour filter, GPS via mobile, Hybrid Auto, Auto Zoom
Display
3" LCD display
Display Format
461,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 (mini-USB Type B) , Composite video/audio output , HDMI output (19 pin micro HDMI Type D)
Software
Software
Drivers & Utilities, Canon Map Utility, Canon Image Transfer Utility, Canon CameraWindow DC
Battery charger, wrist strap
Battery Type
Canon NB-11L, Canon NB-11LH Lithium Ion - manufacturer-specific
Details
Battery Life Details
Photo shooting - 180 shots , Photo shooting - 265 shots (ECO mode) , Playback - 4 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 5184 x 3888 , JPEG 5184 x 3456 , JPEG 5184 x 2912 , JPEG 2592 x 1944 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2048 , JPEG 2048 x 1536 , JPEG 2048 x 1368 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps , H.264 - 640 x 480 - 30 fps , H.264 - 1280 x 720 - 6 fps - Miniature Effect , H.264 - 1280 x 720 - 3 fps - Miniature Effect , H.264 - 1280 x 720 - 1.5 fps - Miniature Effect
9.96 cm
2.28 cm
5.8 cm
147 g
10 - 90%
Optical Zoom: 12
Colour: Black
Brand: Canon
Price Range Ex VAT: 150 - 300
