Canon IXUS 175 Silver Camera Kit inc 16GB SD Card and Case
Quicklinx: BWS5WS00 Mfr#: 1094C009AA & 16GB Case
  • SDHC Memory Card
Slim and stylish with point and shoot simplicity, this IXUS puts superb quality and versatility in your pocket thanks to an 8x optical zoom with 16x ZoomPlus, Smart Auto and instant HD movies.
  • Pocketable style
    This ultra-slim and stylish IXUS fit easily into your bag or pocket and features a flexible 28mm wide 8x optical zoom lens with 16x ZoomPlus; so wherever you go you can easily capture every moment, near or far, in superb quality photos and movies. Keep shooting for longer with Eco Mode, which reduces battery consumption.
  • Instant HD movies
    Making great movies is fun and easy. With one touch of a button you can effortlessly shoot great HD movies (720p) in MP4 format. Experience the creative versatility of shooting movies using the optical zoom and still enjoy superb, sharp results.
  • Superb results
    Enjoy exceptional quality, detailed images thanks to 20.0 Megapixels and DIGIC 4+ processing. Face Detection technology makes capturing great shots of friends effortless, while Auto Zoom intelligently helps you select the best framing at the touch of a button.
  • Point and shoot simplicity
    Just point and shoot to capture fantastic photos or movies with one touch of the Auto Button, which allows Smart Auto to take control and choose the perfect camera settings for you. Enjoy easy viewing and sharing with friends using the 6.8 cm (2.7") LCD screen.
  • Creative play
    Play with your creativity using a range of Creative Filters. Re-create the distortion of a fish-eye lens, make scenes in stills or movies look like miniature scale models and much more. Capture the stunning detail in everyday subjects using 1 cm Macro to get right up close.
Canon IXUS 175 - digital camera
Digital camera - 720p - compact
Memory Card Slot
SD card
Image Processor
DIGIC 4+
Sensor Resolution
20.0 Megapixel
Max Video Resolution
1280 x 720
Lens System
Zoom lens - 8x zoom - 5 - 40 mm - f/3.2-6.9
Focus Adjustment
Automatic
Digital Zoom
4x
Image Stabiliser
Electronic
Camera Flash
Built-in flash
Display
LCD display - 2.7"
Supported Battery
Canon NB-11L Li-ion rechargeable battery - 680 mAh (included) , Canon NB-11LH Li-ion rechargeable battery - 800 mAh (optional)
Composite video/audio, USB 2.0
Silver
9.52 cm x 2.21 cm x 5.43 cm
126 g
Enclosure Colour
Silver
Sensor Resolution
20.0 Megapixel
Optical Sensor Type
CCD
Total Pixels
20,500,000 pixels
Effective Sensor Resolution
20,000,000 pixels
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
25 fps
ISO (Max)
1600
Optical Zoom
8x
Digital Zoom
4x
Image Processor
DIGIC 4+
Image Stabiliser
Electronic
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
9
AE/AF Control
Face-priority AF, Subject-tracking AF, AI Focus AF
Face Detection
Face Detection AF/AE/FE/WB, Face Detection Self-timer
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
1280 x 720
Computer Connectivity
Mac, Windows
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto
Exposure Metering
Evaluative, centre-weighted, spot
Exposure Modes
Programme, automatic
Shooting Programs
Portrait mode, slow shutter, fireworks, low light
Special Effects
Fisheye, monochrome, miniature, Toy camera, Posterisation, Super Vivid
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
15 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
28 - 224mm
Focus Adjustment
Automatic
Macro Focus Range
1cm
Zoom Adjustment
Motorised drive
Lens Construction
7 groups / 8 elements
Built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.5 m - 3 m (wide lens) , 1.3 m - 1.5 m (tele lens)
Additional Features
Continuous Shooting Speed
0.8 frames per second, 2.2 frames per second (5MP)
Self-Timer Delay
10 sec, 2sec
Additional Features
Digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, resizing an image, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, face detection, Smart Flash Exposure, Smart AUTO, primary colour filter, Auto Zoom
Display
2.7" LCD display
Display Format
230,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 (mini-USB Type B) , Composite video/audio output
Software
Software
Drivers & Utilities, Canon CameraWindow DC
Battery charger, wrist strap
Battery Type
Canon NB-11L, Canon NB-11LH Lithium Ion
Details
Battery Life Details
Photo shooting - 220 shots , Photo shooting - 300 shots (ECO mode) , Playback - 4 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Memory Card Included
No
Image Storage
JPEG 5152 x 3864 , JPEG 5152 x 2896 , JPEG 3648 x 2736 , JPEG 2048 x 1536 , JPEG 640 x 480
Video Capture
H.264 - 1280 x 720 - 25 fps , H.264 - 640 x 480 - 30 fps , H.264 - 1280 x 720 - 5 fps - Miniature Effect , H.264 - 1280 x 720 - 2.5 fps - Miniature Effect , H.264 - 1280 x 720 - 1.25 fps - Miniature Effect , H.264 - 640 x 480 - 6 fps - Miniature Effect , H.264 - 640 x 480 - 3 fps - Miniature Effect , H.264 - 640 x 480 - 1.5 fps - Miniature Effect
9.52 cm
2.21 cm
5.43 cm
126 g
10 - 90%
