Slim and stylish with point and shoot simplicity, this IXUS puts superb quality and versatility in your pocket thanks to an 8x optical zoom with 16x ZoomPlus, Smart Auto and instant HD movies.
Pocketable style
This ultra-slim and stylish IXUS fit easily into your bag or pocket and features a flexible 28mm wide 8x optical zoom lens with 16x ZoomPlus; so wherever you go you can easily capture every moment, near or far, in superb quality photos and movies. Keep shooting for longer with Eco Mode, which reduces battery consumption. -
Instant HD movies
Making great movies is fun and easy. With one touch of a button you can effortlessly shoot great HD movies (720p) in MP4 format. Experience the creative versatility of shooting movies using the optical zoom and still enjoy superb, sharp results. -
Superb results
Enjoy exceptional quality, detailed images thanks to 20.0 Megapixels and DIGIC 4+ processing. Face Detection technology makes capturing great shots of friends effortless, while Auto Zoom intelligently helps you select the best framing at the touch of a button. -
Point and shoot simplicity
Just point and shoot to capture fantastic photos or movies with one touch of the Auto Button, which allows Smart Auto to take control and choose the perfect camera settings for you. Enjoy easy viewing and sharing with friends using the 6.8 cm (2.7") LCD screen. -
Creative play
Play with your creativity using a range of Creative Filters. Re-create the distortion of a fish-eye lens, make scenes in stills or movies look like miniature scale models and much more. Capture the stunning detail in everyday subjects using 1 cm Macro to get right up close.
- Canon IXUS 175 - digital camera
- Product Type
- Digital camera - 720p - compact
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 4+
- Sensor Resolution
- 20.0 Megapixel
- Max Video Resolution
- 1280 x 720
- Lens System
- Zoom lens - 8x zoom - 5 - 40 mm - f/3.2-6.9
- Focus Adjustment
- Automatic
- Digital Zoom
- 4x
- Image Stabiliser
- Electronic
- Camera Flash
- Built-in flash
- Display
- LCD display - 2.7"
- Supported Battery
- Canon NB-11L Li-ion rechargeable battery - 680 mAh (included) , Canon NB-11LH Li-ion rechargeable battery - 800 mAh (optional)
- Interface
- Composite video/audio, USB 2.0
- Silver
- 9.52 cm x 2.21 cm x 5.43 cm
- 126 g
- Product Type
- Enclosure Colour
- Silver
- Sensor Resolution
- 20.0 Megapixel
- Optical Sensor Type
- CCD
- Total Pixels
- 20,500,000 pixels
- Effective Sensor Resolution
- 20,000,000 pixels
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 25 fps
- ISO (Max)
- 1600
- Optical Zoom
- 8x
- Digital Zoom
- 4x
- Image Processor
- DIGIC 4+
- Image Stabiliser
- Electronic
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Face-priority AF, Subject-tracking AF, AI Focus AF
- Face Detection
- Face Detection AF/AE/FE/WB, Face Detection Self-timer
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG
- 1280 x 720
- Interface
- Computer Connectivity
- Mac, Windows
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto
- Exposure Metering
- Evaluative, centre-weighted, spot
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Portrait mode, slow shutter, fireworks, low light
- Special Effects
- Fisheye, monochrome, miniature, Toy camera, Posterisation, Super Vivid
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight)
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 15 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 28 - 224mm
- Focus Adjustment
- Automatic
- Macro Focus Range
- 1cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 7 groups / 8 elements
- Built-in lens shield, aspherical lens
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.5 m - 3 m (wide lens) , 1.3 m - 1.5 m (tele lens)
Additional Features
- Continuous Shooting Speed
- 0.8 frames per second, 2.2 frames per second (5MP)
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, resizing an image, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, face detection, Smart Flash Exposure, Smart AUTO, primary colour filter, Auto Zoom
Display
- 2.7" LCD display
- Display Format
- 230,000 pixels
- Display Form Factor
- Built-in
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 (mini-USB Type B) , Composite video/audio output
Software
- Software
- Drivers & Utilities, Canon CameraWindow DC
- Included Accessories
- Battery charger, wrist strap
- Battery Type
- Canon NB-11L, Canon NB-11LH Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 220 shots , Photo shooting - 300 shots (ECO mode) , Playback - 4 hours
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Memory Card Included
- No
- Image Storage
- JPEG 5152 x 3864 , JPEG 5152 x 2896 , JPEG 3648 x 2736 , JPEG 2048 x 1536 , JPEG 640 x 480
- Video Capture
- H.264 - 1280 x 720 - 25 fps , H.264 - 640 x 480 - 30 fps , H.264 - 1280 x 720 - 5 fps - Miniature Effect , H.264 - 1280 x 720 - 2.5 fps - Miniature Effect , H.264 - 1280 x 720 - 1.25 fps - Miniature Effect , H.264 - 640 x 480 - 6 fps - Miniature Effect , H.264 - 640 x 480 - 3 fps - Miniature Effect , H.264 - 640 x 480 - 1.5 fps - Miniature Effect
- 9.52 cm
- 2.21 cm
- 5.43 cm
- 126 g
- 0 °C
- 40 °C
- 10 - 90%
