It's easy to shoot sharp, detailed photos and movies with this slim, stylish 16-megapixel IXUS that's equipped with an 8x optical zoom and optical image stabilizer, and is small enough to fit in your pocket.
Slim, compact and stylish the IXUS 150 captures superb quality, detailed images that are perfect for large-scale prints (A3+) or creative cropping - thanks to a 16-megapixel sensor and a powerful DIGIC 4+ processor, which offers improved speed, performance and functionality for brilliant fast results.
Capture every detail in IXUS style
Slim, compact and stylish the IXUS 150 captures superb quality, detailed images that are perfect for large-scale prints (A3+) or creative cropping - thanks to a 16-megapixel sensor and a powerful DIGIC 4+ processor, which offers improved speed, performance and functionality for brilliant fast results. -
Shoot far and wide
Shoot every moment with ease using the flexibility of a 28mm wide 8x optical zoom lens. Get nearer to distant subjects using the 8x optical zoom or get even closer without any loss of quality with 16x ZoomPlus. -
Beautiful sharp results
Whatever you're shooting your photos and videos will be sharp and detailed - even on the move, at full zoom or in low light - thanks to advanced Intelligent IS. It automatically adjusts the optical image stabilizer to the scene using 8 different modes to counteract camera shake and prevent blur. -
Effortless point and shoot
Anyone can effortlessly shoot high quality photos or movies with smart auto, which detects the scene and automatically selects the right settings from 32 variables. Press the auto button to return instantly to smart auto from any other mode. Use the help button for quick, easy-to-follow guidance on using your camera and its functions. -
Easy framing, live view control
Frame and view your shots with ease and enjoy sharing them with friends using the 6.8 cm (2.7") LCD screen. You can experiment with picture settings such as brightness and color intensity and preview the results while framing using live view control. -
Instant HD movies with movie button
It is instantly record high quality HD movies (720p) with optical zoom by simply pressing the dedicated movie button. -
Great people shots
Enjoy great people shots with Face Detection technology. It detects multiple faces in a single frame making sure they remain in focus and with optimum brightness. Face Detection White Balance ensures natural skin tones even in unusual lighting conditions. -
Fun and creative effects
Experiment and have fun with a range of creative modes such as fish-eye effect, super vivid, or monochrome. miniature effect makes scenes in stills or movies look like miniature scale models. -
Eco mode
Capture more shots from a single battery charge with Eco mode, which reduces battery consumption.
- Canon IXUS 150 - digital camera
- Product Type
- Digital camera - 720p - compact
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 4+
- Sensor Resolution
- 16.0 Megapixel
- Max Video Resolution
- 1280 x 720
- Lens System
- Zoom lens - 8x zoom - 5 - 40 mm - f/3.2-5.9
- Focus Adjustment
- Automatic
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (Intelligent IS with Advanced Dynamic Mode)
- Camera Flash
- Built-in flash
- Display
- LCD display - 2.7"
- Supported Battery
- Canon NB-11L Li-ion rechargeable battery - 680 mAh (included)
- Interface
- Composite video/audio, USB 2.0
- Grey
- 9.52 cm x 2.21 cm x 5.43 cm
- 130 g
- Product Type
- Enclosure Colour
- Grey
- Sensor Resolution
- 16.0 Megapixel
- Optical Sensor Type
- CCD
- Effective Sensor Resolution
- 16,000,000 pixels
- Optical Sensor Size
- 1/2.3"
- ISO (Max)
- 1600
- Optical Zoom
- 8x
- Digital Zoom
- 4x
- Image Processor
- DIGIC 4+
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Face-priority AF, Subject-tracking AF
- Face Detection
- Face Detection AF/AE/FE/WB, Face Detection Self-timer
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG
- 1280 x 720
- Interface
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto
- Exposure Metering
- Evaluative, centre-weighted, spot
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Portrait mode, slow shutter, fireworks, low light, snow
- Special Effects
- Fisheye, monochrome, miniature, Toy camera, Posterisation, Super Vivid
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight)
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 15 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
- X-sync Speed
- 1/2000 sec
Lens System
- Focal Length Equivalent to 35mm Camera
- 28 - 224mm
- Focus Adjustment
- Automatic
- Macro Focus Range
- 1cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 7 groups / 8 elements
- Built-in lens shield, aspherical lens
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.5 m - 3 m (wide lens) , 1.3 m - 1.5 m (tele lens)
Additional Features
- Continuous Shooting Speed
- 0.8 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Histogram display, AE lock, AF lock, resizing an image, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, face detection, built-in help guide, Smart Flash Exposure, Smart AUTO, Live View Control, primary colour filter
Display
- 2.7" LCD display
- Display Format
- 230,000 pixels
- Display Form Factor
- Built-in
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 , Composite video/audio output
Software
- Software
- Drivers & Utilities, Canon PhotoStitch, Canon ImageBrowser EX, Canon CameraWindow
- Included Accessories
- Battery charger, USB cable, wrist strap
- Battery Type
- Canon NB-11L Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 210 shots , Photo shooting - 280 shots (ECO mode) , Playback - 4 hours
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Image Storage
- JPEG 4608 x 3456 , JPEG 4608 x 2592 , JPEG 3264 x 2448 , JPEG 2048 x 1536 , JPEG 640 x 480
- Video Capture
- H.264 - 1280 x 720 - 25 fps , H.264 - 640 x 480 - 30 fps , H.264 - 1280 x 720 - 5 fps - Miniature Effect , H.264 - 1280 x 720 - 2.5 fps - Miniature Effect , H.264 - 1280 x 720 - 1.25 fps - Miniature Effect , H.264 - 640 x 480 - 6 fps - Miniature Effect , H.264 - 640 x 480 - 3 fps - Miniature Effect , H.264 - 640 x 480 - 1.5 fps - Miniature Effect
- 9.52 cm
- 2.21 cm
- 5.43 cm
- 130 g
- 0 °C
- 40 °C
- 10 - 90%
