This easy to use network-ready multifunctional device makes it ideal for small businesses to share impressive color prints from PC or mobile devices. Easy-to-use, with intuitive navigation and a clear color display, the network-ready i-SENSYS MF8230Cn makes it simple to share color printing, copying and scanning across workgroups.
With mobile printing it's simple to connect smartphones and tablets to the i-SENSYS MF8230Cn, from virtually anywhere in the office. Print emails, web pages and other documents directly from your iPhone or iPad using the support of Apple AirPrint, which automatically detects the printer on your network.
For more productive working, the i-SENSYS MF8230Cn prints and copies at 14 pages per minute, for both color and mono documents and has a 50-sheet automatic document feeder. There's also little time lost waiting for output thanks to Canon's Quick First-Print technologies and a fast first copy out Time. Advanced image quality, with up to 1200 x 1200 dpi resolution, ensures bright, vibrant output every time.
Network-ready all-in-one
Increase team productivity with this compact, stylish multifunctional, which supports mobile printing and fits neatly on any office desktop. Easy-to-use, with intuitive navigation and a clear color display, the network-ready i-SENSYS MF8230Cn makes it simple to share color printing, copying and scanning across workgroups. -
Easy sharing
With mobile printing it's simple to connect smartphones and tablets to the i-SENSYS MF8230Cn, from virtually anywhere in the office. Print emails, web pages and other documents directly from your iPhone or iPad using the support of Apple AirPrint, which automatically detects the printer on your network. -
Fast, quality output
For more productive working, the i-SENSYS MF8230Cn prints and copies at 14 pages per minute, for both color and mono documents and has a 50-sheet automatic document feeder. There's also little time lost waiting for output thanks to Canon's Quick First-Print technologies and a fast first copy out Time. Advanced image quality, with up to 1200 x 1200 dpi resolution, ensures bright, vibrant output every time. -
Simple to operate and maintain
One-touch solution keys and intuitive menus, make it straightforward for anyone to operate and maintain. Productivity is boosted by easy scanning and eco-copying, which combines several pages into a single print-out saving paper and money. A backlit, 7-line color screen clearly displays all the essential information users need. The all-in-one cartridge simplifies maintenance and increases reliability. -
Fast document distribution
Conveniently share documents by scanning across a network connection or straight to USB memory key. -
Save energy and cut costs
Save costs without compromising on performance, while cutting your carbon footprint, using Canon's On-Demand fixing technology. ENERGY STAR compliant, the i-SENSYS MF8230Cn is among the most energy-efficient multifunctional in its class with a market-leading low energy consumption of just 1 W in sleep mode.
- Canon i-SENSYS MF8230Cn - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 impressions
- Max Copying Speed
- Up to 14 ppm (mono) / up to 14 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 3.5"
- Original Size
- 128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 83 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, coated paper, heavy-weight paper
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 125 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Document send function, save to USB flash drive
- Power
- AC 230 V (50/60Hz)
- 43 cm x 48.4 cm x 42.9 cm
- 26 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- 30000 impressions
- Display
- 7 lines
- Display Diagonal Size
- 3.5"
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Printer Drivers / Emulations
- UFRII LT
- First Print Out Time B/W
- 18 sec
- First Print Out Time Colour
- 18 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Min Original Size
- 128 x 139.7 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 83 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 1 sheet
- 125 sheets
- ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 150 sheets size: 83 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 1 sheet size: 83 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 125 sheets
- Speed Details
- Printing: up to 14 ppm (A4) - colour , Printing: up to 14 ppm (A4) - B/W , Copying: up to 14 ppm (A4) - colour , Copying: up to 14 ppm (A4) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- IPsec, 802.1x
- Operating System Support
- MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8
- Software Included
- Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
- Voltage Required
- 900 Watt
- Power Consumption Standby
- 23 Watt
- Power Consumption Sleep
- 1 Watt
- Warm-Up Time
- 23 sec
- First Copy Out Time B/W
- 19 sec
- First Copy Out Time Colour
- 19 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 800 pages - Canon 731 Starter , 1 x toner cartridge (cyan) - up to 800 pages - Canon 731 Starter , 1 x toner cartridge (magenta) - up to 800 pages - Canon 731 Starter , 1 x toner cartridge (yellow) - up to 800 pages - Canon 731 Starter
- ENERGY STAR Certified
- 43 cm
- 48.4 cm
- 42.9 cm
- 26 kg
- Sound Emission
- 46.7 dBA (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
