Take your printing to a higher level with a beautifully compact professional A3+ printer that has all the qualities of the imagePROGRAF PRO range, rewarding you with rich, vibrant and exquisite gallery-quality prints every time.
Small footprint, big potential
This stylish and compact A3+ printer is at the heart of your creative output, connecting easily with PC or Mac using Wi-Fi or Ethernet. -
Gallery-quality printing with no ink switching
Achieve professional results on a wide variety of media up to A3+ in super-quick time thanks to zero ink switching. -
Print without borders on a wide variety of media
Achieve borderless printing on glossy or fine art papers and print panoramic images to custom lengths up to 990.60mm. -
Enhanced color gamut for greater depth
Using 10 LUCIA PRO pigment inks, the printer delivers an outstanding color with a dedicated chroma optimizer ink to reduce bronzing and deliver stunning tonal superiority. -
3-inch color LCD menu screen
Quickly navigate the printer's menus and functions thanks to a clear bright display that allows instant monitoring of printer functions, ink levels and paper settings. -
Outstanding monochrome print quality
The imagePROGRAF PRO-300's matte black ink enables greater expression of monochrome images with deeper and more vivid blacks on fine art paper. -
High-speed and high-quality printing
Canon's L-COA PRO processor easily handles large image data and calculates precise ink delivery at super-fast speeds to produce high-quality prints without compromise.
- Canon imagePROGRAF PRO-300 - large-format printer - colour - ink-jet
- Printer Type
- 13" large-format printer - ink-jet - colour
- 14.4 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 10-ink - cyan, magenta, yellow, photo black, matte black, grey, photo cyan, photo magenta, red, chroma optimiser
- Media Size Class
- A3/Ledger
- Max Media Size
- 355.6 x 990.6 mm
- Min Media Size (Custom)
- 89 mm x 127 mm
- Max Media Size (Custom)
- 355.6 mm x 990.6 mm
- Print Speed
- Up to 4.25 min/page - B/W , Up to 4.25 min/page - colour
- Max Resolution (Colour)
- 4800 x 2400 dpi
- Print on CD/DVD
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Media Type
- Plain paper, photo paper, photo stickers, fine art paper, CD discs, glossy paper, matte paper, semi-gloss paper, nail stickers
- Total Media Capacity
- 100 sheets
- Media Handling
- 100-sheet input tray, 1-sheet multipurpose tray, 1-sheet manual tray
- Networking
- Print server
- Printer Features
- Borderless printing, Canon L-COA PRO
- Power
- AC 120/230 V
- System Requirements
- Android, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Apple iOS, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Windows 10 Mobile, Apple MacOS X 10.11.6, Microsoft Windows Server 2019, Apple macOS 10.12 - 10.15
- 63.9 cm x 37.9 cm x 20 cm
- 2 Years
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 7680 nozzles
- Ink Cartridge Configuration
- 10 individual ink tanks
- Ink Type
- Canon LUCIA PRO pigment ink
- Print Speed
- Built-in Devices
- 3 inch LCD display
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 4800 x 2400 dpi
- Print on CD/DVD
- Direct Printing Specifications
- PictBridge
- Printer Features
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- 355.6 x 990.6 mm
- 89 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), Panoramic A2 (210 x 594 mm), 101.6 x 152.4 mm, 89 x 127 mm, 76.2 x 127 mm, 127 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 304.8 x 304.8 mm, 254 x 304.8 mm, 177.8 x 254 mm, 355.6 x 990.6 mm
- Media Weight
- 64 g/m² - 380 g/m²
- 100 sheets
- Media Feeders
- Input tray: 1 - 100 sheets - 355.6 x 990.6 mm weight: 64 g/m² - 380 g/m² , Input tray: 1 - 1 sheet - 355.6 x 990.6 mm 380 g/m² , Multi-purpose tray: 1 - 1 sheet - 120 x 120 mm
- Networking
- Print server
- Remote Management Protocol
- SNMP, HTTP, IPv4, IPv6
- WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, EAP-TTLS, EAP-TLS, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Included Accessories
- CD/DVD tray
- Consumables Included
- Printhead , 1 x ink tank (matte black) , 1 x ink tank (photo black) , 1 x ink tank (grey) , 1 x ink tank (cyan) , 1 x ink tank (photo cyan) , 1 x ink tank (magenta) , 1 x ink tank (photo magenta) , 1 x ink tank (yellow) , 1 x ink tank (red) , 1 x ink tank (chroma optimiser)
- PIXMA Cloud Link
- RoHS, WEEE
- Power Device
- Power supply - internal
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 16 Watt
- Power Consumption Stand by
- 2.4 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
- Sound Emission (Operating)
- 41.1 dBA
- 63.9 cm
- 37.9 cm
- 20 cm
- 14.4 kg
- 2 Years
Canon PFI-300 Cyan Ink Cartridge 14ml | In Stock | £12.36 |
Canon PFI-300 Chroma Optimizer Ink Cartridge 14ml | In Stock | £12.74 |
Canon PFI-300 Grey Ink Cartridge 14ml | In Stock | £12.73 |
Canon PFI-300 Magenta Ink Cartridge 14ml | In Stock | £12.94 |
Canon PFI-300 Matte Black Ink Cartridge 14ml | In Stock | £12.94 |
Canon PFI-300 Photo Black Ink Cartridge 14ml | In Stock | £12.74 |
Canon PFI-300 Photo Cyan Ink Cartridge 14ml | In Stock | £12.36 |
Canon PFI-300 Photo Magenta Ink Cartridge | In Stock | £12.94 |
Canon PFI-300 Red Ink Cartridge 14ml | In Stock | £12.94 |
Canon PFI-300 Yellow Ink Cartridge 14ml | In Stock | £13.38 |
