Canon imagePROGRAF PRO-300 Colour Ink-Jet Large Format Printer
Quicklinx: G1HKWS00 Mfr#: 4278C008AA
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
£596.23 ex VAT
£715.47 inc VAT
Take your printing to a higher level with a beautifully compact professional A3+ printer that has all the qualities of the imagePROGRAF PRO range, rewarding you with rich, vibrant and exquisite gallery-quality prints every time.
  • Small footprint, big potential
    This stylish and compact A3+ printer is at the heart of your creative output, connecting easily with PC or Mac using Wi-Fi or Ethernet.
  • Gallery-quality printing with no ink switching
    Achieve professional results on a wide variety of media up to A3+ in super-quick time thanks to zero ink switching.
  • Print without borders on a wide variety of media
    Achieve borderless printing on glossy or fine art papers and print panoramic images to custom lengths up to 990.60mm.
  • Enhanced color gamut for greater depth
    Using 10 LUCIA PRO pigment inks, the printer delivers an outstanding color with a dedicated chroma optimizer ink to reduce bronzing and deliver stunning tonal superiority.
  • 3-inch color LCD menu screen
    Quickly navigate the printer's menus and functions thanks to a clear bright display that allows instant monitoring of printer functions, ink levels and paper settings.
  • Outstanding monochrome print quality
    The imagePROGRAF PRO-300's matte black ink enables greater expression of monochrome images with deeper and more vivid blacks on fine art paper.
  • High-speed and high-quality printing
    Canon's L-COA PRO processor easily handles large image data and calculates precise ink delivery at super-fast speeds to produce high-quality prints without compromise.
Canon imagePROGRAF PRO-300 - large-format printer - colour - ink-jet
Printer Type
13" large-format printer - ink-jet - colour
14.4 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
10-ink - cyan, magenta, yellow, photo black, matte black, grey, photo cyan, photo magenta, red, chroma optimiser
Media Size Class
A3/Ledger
Max Media Size
355.6 x 990.6 mm
Min Media Size (Custom)
89 mm x 127 mm
Max Media Size (Custom)
355.6 mm x 990.6 mm
Print Speed
Up to 4.25 min/page - B/W , Up to 4.25 min/page - colour
Max Resolution (Colour)
4800 x 2400 dpi
Print on CD/DVD
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Media Type
Plain paper, photo paper, photo stickers, fine art paper, CD discs, glossy paper, matte paper, semi-gloss paper, nail stickers
Total Media Capacity
100 sheets
Media Handling
100-sheet input tray, 1-sheet multipurpose tray, 1-sheet manual tray
Print server
Printer Features
Borderless printing, Canon L-COA PRO
AC 120/230 V
Android, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Apple iOS, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Windows 10 Mobile, Apple MacOS X 10.11.6, Microsoft Windows Server 2019, Apple macOS 10.12 - 10.15
63.9 cm x 37.9 cm x 20 cm
2 Years
Printer Type
Printer
Inkjet Technology
Nozzle Configuration
7680 nozzles
Ink Cartridge Configuration
10 individual ink tanks
Ink Type
Canon LUCIA PRO pigment ink
Print Speed
Built-in Devices
3 inch LCD display
Wireless
AirPrint Enabled
4800 x 2400 dpi
Print on CD/DVD
Direct Printing Specifications
PictBridge
Printer Features
Media Handling
Media Handling
Media Type
Media Size Class
A3/Ledger
Max Media Size
355.6 x 990.6 mm
89 mm x 127 mm
355.6 mm x 990.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), Panoramic A2 (210 x 594 mm), 101.6 x 152.4 mm, 89 x 127 mm, 76.2 x 127 mm, 127 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 304.8 x 304.8 mm, 254 x 304.8 mm, 177.8 x 254 mm, 355.6 x 990.6 mm
Media Weight
64 g/m² - 380 g/m²
100 sheets
Media Feeders
Input tray: 1 - 100 sheets - 355.6 x 990.6 mm weight: 64 g/m² - 380 g/m² , Input tray: 1 - 1 sheet - 355.6 x 990.6 mm 380 g/m² , Multi-purpose tray: 1 - 1 sheet - 120 x 120 mm
Print server
Remote Management Protocol
SNMP, HTTP, IPv4, IPv6
Security Protocols & Features
WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, EAP-TTLS, EAP-TLS, PEAP
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
CD/DVD tray
Consumables Included
Printhead , 1 x ink tank (matte black) , 1 x ink tank (photo black) , 1 x ink tank (grey) , 1 x ink tank (cyan) , 1 x ink tank (photo cyan) , 1 x ink tank (magenta) , 1 x ink tank (photo magenta) , 1 x ink tank (yellow) , 1 x ink tank (red) , 1 x ink tank (chroma optimiser)
PIXMA Cloud Link
RoHS, WEEE
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
16 Watt
Power Consumption Stand by
2.4 Watt
Software Included
Drivers & Utilities
5 °C
35 °C
10 - 80% (non-condensing)
Sound Emission (Operating)
41.1 dBA
63.9 cm
37.9 cm
20 cm
14.4 kg
2 Years
G1HK Canon PFI-300 Cyan Ink Cartridge 14ml In Stock £12.36
G1HK Canon PFI-300 Chroma Optimizer Ink Cartridge 14ml In Stock £12.76
G1HK Canon PFI-300 Grey Ink Cartridge 14ml In Stock £12.96
G1HK Canon PFI-300 Magenta Ink Cartridge 14ml In Stock £12.96
G1HK Canon PFI-300 Matte Black Ink Cartridge 14ml In Stock £12.96
G1HK Canon PFI-300 Photo Black Ink Cartridge 14ml In Stock £12.76
G1HK Canon PFI-300 Photo Cyan Ink Cartridge 14ml In Stock £12.36
G1HK Canon PFI-300 Photo Magenta Ink Cartridge In Stock £12.96
G1HK Canon PFI-300 Red Ink Cartridge 14ml In Stock £12.96
G1HK Canon PFI-300 Yellow Ink Cartridge 14ml In Stock £12.96
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: 355.6 x 990.6 mm
Brand: Canon
Price Range Ex VAT: £500 - £750
