Canon imageFORMULA DR-M160II Document Scanner
Quicklinx: 9KX5WS00 Mfr#: 9725B003
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 3000 mm
Interface: USB 2.0
Compatibility: PC, Mac
Hurry, only 2 left in stock!
£538.79 ex VAT
£646.54 inc VAT
Well suited for workgroups and departments in any industry, the DR-M160II scanner provides the basis for efficient records management and helps reduce paperwork. It delivers capture capabilities that make it an ideal addition, especially in the legal, financial, healthcare, and government sectors.
The strength of the DR-M160II scanner is seen in its throughput, capacity, and overall performance. Scanning up to 60 pages per minute - both sides in a single pass - and holding up to 60 sheets in the ADF, it quickly captures and converts paperbased documents into usable, digital information.
  • Efficient duplex scanning
    The Canon imageFORMULA DR-M160II offers automatic duplexing, enabling fast double-sided scanning at speeds up to 120 images per minute, making it suitable for high-volume document management workflows.
  • High-quality imaging
    With a color depth of 24-bit and grayscale depth of 8-bit, this scanner produces sharp, vivid images with 16.7 million colors and 256 gray levels, ensuring that your documents look as close to the original as possible.
  • Versatile document handling
    Capable of scanning documents up to 216 mm by 3000 mm and equipped with a 60-sheet feeder, the DR-M160II can handle a variety of media types and sizes, from business cards to long documents, with ease.
  • Advanced scanning features
    Features like Advanced Text Enhancement, Deskew, and Ultrasonic Double Feed Detection improve the accuracy and efficiency of scans, reducing the need for rescans and manual corrections.
  • Energy-efficient operation
    ENERGY STAR certification ensures that the Canon imageFORMULA DR-M160II is not only powerful but also energy-efficient, helping to reduce operational costs and your carbon footprint.
Canon imageFORMULA DR-M160II - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CMOS / CIS
Light Source
RGB LED array
Max Supported Document Size
216 x 3000 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 3000 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Storage Capacity
60 sheets
Duty Cycle
7000 scans per day
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1, Windows 10
28 cm x 17.2 cm x 17.8 cm
3.2 kg
Environmental Standards
ENERGY STAR Qualified
Mnaufacturer Warranty
2 Years
Interface Type
USB 2.0
216 x 3000 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi
Automatic Duplexing
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
7000 scans per day
Scanner Speed Details
60 ppm - portrait B&W - A4 - 200 dpi , 60 ppm - portrait greyscale - A4 - 200 dpi , 60 ppm - portrait colour - A4 - 200 dpi , 120 ipm - duplex - portrait B&W - A4 - 200 dpi , 120 ipm - duplex - portrait greyscale - A4 - 200 dpi , 120 ipm - duplex - portrait colour - A4 - 200 dpi
Scanner Features
Ultrasonic Double Feed Detection, Error Diffusion, Moire Reduction, Patch Code Detection, automatic colour detection, automatic page size detection, blank page skipping, MultiStream Technology, Advanced Text Enhancement, Batch Separation, RGB Color Dropout, automatic resolution setting, Smooth Background, 3 Dimensional Color Correction processing, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Double Feed Release (DFR), Shadow Cropping, Deskew, Shading Correction, Preset Gamma Curve, Color Enhancement, Contrast Arrangment, Color Drift, Color Elimination, Edge Enhancement, Long Document Scanning, Stretch Adjustment of Sub-Scanning Direction
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 3000 mm
Plain paper
60 sheets
USB 2.0
RoHS
ENERGY STAR Certified
Power Consumption Operational (Standby)
27 Watt (1.8 Watt)
Software Included
Drivers & Utilities, Canon CapturePerfect, Kofax VirtualReScan, Canon CaptureOnTouch, Nuance eCopy PDF Pro Office, EMC Captiva Cloud Runtime Controls
28 cm
17.2 cm
17.8 cm
3.2 kg
10 °C
32.5 °C
20 - 80%
Service and Support
2 Years
Interface: USB 2.0
Compatibility: PC
Compatibility: Mac
Brand: Canon
Price Range Ex VAT: £500 - £750
Stock Status: While stocks last
Stock Status: Clearance
