Canon imageFORMULA DR-C240 Document Scanner
AFFORDABLE TO RUN AND MAINTAIN!
Quicklinx: BF93WS00 Mfr#: 0651C003
Type: Document scanner
Form Factor: Desktop
Interface: USB 2.0
Compatibility: PC
19 In Stock
£258.67 ex VAT
£310.40 inc VAT
Compact document scanner perfect for busy workgroups and customer-facing environments.
The imageFORMULA DR-C240 is an ultra-compact and powerful desktop scanner featuring a robust design and reliable paper handling for capturing multiple document sizes and formats, including passports.
Main Features
  • Boost productivity with fast 2-sided scanning at up to 90ipm.
  • Easily scan various types of documents including passports with one compact device.
  • Enjoy peace of mind with supreme paper-handling reliability and durable construction.
  • Enhance your environment with quiet operation, compact build and elegant design.
High-performance and flexible applications
The imageFORMULA DR-C240’s premium build quality and productivity-focused features are a breakthrough in this value segment. Offering rapid scanning at up to 45ppm/90ipm, the imageFORMULA DR-C240 is the natural all-round choice for office departments and workgroups. Its quiet operation – and compact, attractive desktop design – make a great impression in front offices and customer service points, for example in banks, hotels, hospitals and government offices.
Designed in response to customers’ needs
The imageFORMULA DR-C240’s robust construction and rugged document feeder were developed as a direct result of customer feedback. It represents a step forward in build quality in this scanner’s segment, effortlessly capturing up to 4,000 scans per day. Your productivity is maximised by the 60-sheet ADF that reliably feeds batches of mixed-sized document and media types: from passports and plastic cards to duplex A4, A3 (using folio) and long documents up to 3m in length.
Precision paper handling
To keep your workflows fluid, the imageFORMULA DR-C240 offers a powerful, high-quality feeding mechanism that ensures best in class reliability for scanning various documents, including ultra-thin papers from 27gsm. The ultrasonic Double Feed Detection and Double Feed Release (DFR) function allow scanning to restart quickly, keeping downtime to a minimum.
Easy operation, consistent results
The imageFORMULA DR-C240 includes a wide range of high quality image processing capabilities. These include automatic page size and text direction detection, text enhancement, a deskew function and automatic colour detection. The user-friendly control panel lets operators scan with a press of a button – accelerating and simplifying scanning tasks.
Affordable to run and maintain
It’s hassle-free to replace the imageFORMULA DR-C240’s long-life retard roller and feed roller unit yourself, which keeps your cost of ownership to a minimum. Impressively low power consumption, at just 19W in operation and 1.4W in standby, further drives down overheads while minimising your environmental impact.
  • High-performance and flexible applications
    The imageFORMULA DR-C240's premium build quality and productivity-focused features are a breakthrough in this value segment. Offering rapid scanning at up to 45ppm/90ipm, the imageFORMULA DR-C240 is the natural all-round choice for office departments and workgroups. Its quiet operation - and compact, attractive desktop design - make a great impression in front offices and customer service points, for example in banks, hotels, hospitals and government offices.
  • Designed in response to customers' needs
    The imageFORMULA DR-C240's robust construction and rugged document feeder were developed as a direct result of customer feedback. It represents a step forward in build quality in this scanner's segment, effortlessly capturing up to 4,000 scans per day. Your productivity is maximized by the 60-sheet ADF that reliably feeds batches of mixed-sized document and media types: from passports and plastic cards to duplex A4, A3 (using folio) and long documents up to 3m in length.
  • Precision paper handling
  • Easy operation, consistent results
    The imageFORMULA DR-C240 includes a wide range of high quality image processing capabilities. These include automatic page size and text direction detection, text enhancement, a deskew function and automatic color detection. The user-friendly control panel lets operators scan with a press of a button - accelerating and simplifying scanning tasks.
  • Rich software bundle
    Canon's advanced CapturePerfect application enables efficient batch scanning and supports the included Kofax VRS driver for enhanced image quality. To intuitively scan documents, then easily send them to multiple destinations (including cloud services) simply use Canon's CaptureOnTouch. The bundled eCopy PDF Pro provides powerful PDF creation, editing and conversion tools.
  • Affordable to run and maintain
    It's hassle-free to replace the imageFORMULA DR-C240's long-life retard roller and feed roller unit yourself, which keeps your cost of ownership to a minimum. Impressively low power consumption, at just 19W in operation and 1.4W in standby, further drives down overheads while minimizing your environmental impact.
Canon imageFORMULA DR-C240 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CMOS / CIS
Light Source
RGB LED array
Max Supported Document Size
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
45 ppm (mono) / 30 ppm (colour)
Max Document Size
216 mm x 3000 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
60 sheets
Duty Cycle
4000 scans per day
Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Windows 8, Microsoft Windows Server 2012 R2, Windows 8.1
Microsoft Certification
Compatible with Windows 7
29.1 cm x 25.3 cm x 23.1 cm
2.8 kg
Environmental Standards
ENERGY STAR Qualified
2 Years
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
45 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
4000 scans per day
Scanner Speed Details
45 ppm - black & white , 90 ipm - duplex - black & white , 30 ppm - colour , 60 ipm - duplex - colour
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Error Diffusion, Moire Reduction, automatic colour detection, automatic page size detection, blank page skipping, MultiStream Technology, Advanced Text Enhancement, Batch Separation, Smooth Background, 3 Dimensional Color Correction processing, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Double Feed Release (DFR), Shadow Cropping, Deskew, Color Enhancement, Contrast Arrangment, Auto Resolution, Long Document Scanning, Scan Area Setting
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 3000 mm
Automatic
60 sheets
USB 2.0 - Type B
RoHS
ENERGY STAR Certified
Power Consumption Operational (Standby)
19 Watt
Power Consumption Sleep
1.4 Watt
Software Included
Drivers & Utilities, Canon CapturePerfect, Kofax VirtualReScan, Canon CaptureOnTouch, Nuance eCopy PDF Pro Office
29.1 cm
25.3 cm
23.1 cm
2.8 kg
10 °C
32.5 °C
20 - 80%
Service and Support
2 Years
Interface: USB 2.0
Compatibility: PC
Brand: Canon
