Canon imageFORMULA DR-C225 II Document Scanner
Quicklinx: F12JWS00 Mfr#: 3258C003
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 2.0
Compatibility: Android, Apple iOS, Mac, PC
18 In Stock
£225.59 ex VAT
£270.70 inc VAT
Sleek and slim, the DR-C225 II is made for tight spaces. With CaptureOnTouch software for even better usability, it's a true scanning solution.
  • Sleek space-saving design
    A perfect match for a small office desktop or department, a slimline profile ensures the DR-C225 II fits in the smallest space. With powerful CaptureOnTouch software and straightforward integration with cloud networks, it's the ultimate space-saver.
  • A compact fit for tight spaces
    Save even more space with this ultra-slim scanner. The innovative J-Path design ensures a small desktop footprint with 'face up' document scanning for easy use.
  • Ultra-slim, ultra-fast
    Enjoy speedy duplex scanning of up to 50 ipm at 300 dpi and color speeds of up to 25 ppm. Ultrasonic Double Feed Detection also ensures reliable paper handling for fast scanning.
  • Outstanding operation
    CaptureOnTouch software makes scanning simple. One-touch operation completes tricky tasks in seconds while Full Auto Mode intuitively selects the best settings.
  • Innovation for intuitive use
    Guide your way through the scanning process using the step-by-step icon-based user interface and create searchable PDF documents for straightforward document filing.
Canon imageFORMULA DR-C225 II - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CMOS / CIS
Light Source
RGB LED
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
25 ppm (mono) / 25 ppm (colour)
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
30 sheets
Duty Cycle
1500 scans per day
Apple MacOS, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Android, Windows 8, Apple iOS, Windows 10
30 cm x 15.6 cm x 22 cm
2.8 kg
Environmental Standards
ENERGY STAR Qualified
2-year Limited Warranty
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
CMOS / CIS
Bulb / Light Source Type
RGB LED
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
25 ppm
Duty Cycle
1500 scans per day
Scanner Speed Details
25 ppm - black & white , 50 ipm - duplex - black & white , 25 ppm - colour , 50 ipm - duplex - colour
Scanner Features
Ultrasonic Double Feed Detection, Error Diffusion, Moire Reduction, automatic page size detection, blank page skipping, MultiStream Technology, Advanced Text Enhancement, Text Orientation Recognition, RGB Color Dropout, Smooth Background, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Image Rotation, Deskew, Auto Resolution, Red Color Enhancement, Erase Shadow, Pre-Scan, Job Setting, Ultrasonic sensor
TWAIN, ISIS
Media Handling
Automatic
30 sheets
USB 2.0 - Type B
USB cable
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
12.7 Watt
Power Consumption Sleep
1.8 Watt
Software Included
Drivers & Utilities, Cardiris, Canon CaptureOnTouch, Nuance eCopy PDF Pro Office, Google Docs, SharePoint for Windows, SharePoint for Mac, EMC Captiva Cloud Runtime Controls, Google Docs for Mac, SugarSync, Dropbox
30 cm
15.6 cm
22 cm
2.8 kg
10 °C
32.5 °C
20 - 80%
Interface: USB 2.0
Compatibility: Apple iOS
Compatibility: Mac
Compatibility: PC
Brand: Canon
