Canon imageFormula DR-6030C Document Scanner
Quicklinx: 9KX8WS00 Mfr#: 4624B003
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 300 x 432 mm
Interface: USB 2.0, SCSI
Compatibility: PC
£2,437.81 ex VAT
£2,925.37 inc VAT
Canon's imageFORMULA DR-6030C departmental scanner blends high speeds and reliable document handling with versatility and convenience. The DR-6030C scanner provides comprehensive functionality in a desktop design that effectively delivers document capture benefits in any business application.
Benefits
* Ultra-compact A3 production scanner
* High-speed colour scanning (60ppm portrait / 80ppm landscape)
* Advanced image processing features
* Ultra-reliable paper transport system
* Class-leading energy efficiency
* Optional Flatbed 101 Scanner Unit
* Kofax VRS included
Detailed Features
Take a more detailed look into the Canon imageFORMULA DR-6030C
Exceptional speed and efficiency
Busy working environments will quickly raise their productivity with the DR-6030C’s rapid colour scanning speeds. Canon’s advanced 3-line CMOS CIS sensor technology and JPEG-compression image file transfer process enable colour scanning speeds of up to 80ppm (landscape.)
Compact by design
The DR-6030C is among the most compact A3 production scanners – ideal in corporate office departments or smaller branch offices that have limited desktop space. Scan operators will appreciate its convenient front document feed and exit design for its convenient and comfortable operation.
Excellent performance and superior image quality
The DR-6030C captures precise high-quality images scan after scan. With three dedicated modes designed to enhance text and remove dark or patterned backgrounds, the DR-6030C reproduces clear legible images optimized for OCR applications or for automated data extraction. Additional features like Auto Colour Detection, Auto Size and Deskew Correction, Text Orientation Correction and Customised Colour Dropout further enhance image quality and consistency.
Trouble-free paper handling
Built on the same reliable paper transport system as its market-leading DR-5010C predecessor, the DR-6030C can reliably handle up to 10,000 scans a day. The high-precision roller system allows for jam-free feeding of a wide range of documents: from A3 media and plastic cards to documents up to 3m long. A selectable straight-thru paper path makes it easy to scan items up to 546 g/m² thick.
Leading energy efficiency
The DR-6030C is the most energy-efficient production scanner in its class, using just 46W of power when scanning – saving you money and helping you become more eco-friendly.
Powerful Software
The DR-6030C comes bundled with Canon’s CapturePerfect and CapturePerfect Software Developers Kit (SDK) for easy custom integrations. Kofax VRS – the industry’s leading image processing software – is also included for added image quality assurance.
Flatbed option
For extra versatility, the DR-6030C is fully compatible with the optional Flatbed Unit 101 for scanning bound and fragile documents.
  • Compact A3 production scanner for dependable high-quality scanning
    Compact and ergonomically-designed, the imageFORMULA DR-6030C scanner speeds up workflows and boosts productivity with fast, precise A3 color scanning across a range of media.
  • Exceptional speed and efficiency
    Busy working environments will quickly raise their productivity with the DR-6030C's rapid color scanning speeds. Canon's advanced 3-line CMOS CIS sensor technology and JPEG-compression image file transfer process enable color scanning speeds of up to 80ppm (landscape).
  • Compact by design
    The DR-6030C is among the most compact A3 production scanners - ideal in corporate office departments or smaller branch offices that have limited desktop space. Scan operators will appreciate its convenient front document feed and exit design for its convenient and comfortable operation.
  • Excellent performance and superior image quality
  • Trouble-free paper handling
Canon imageFORMULA DR-6030C - document scanner
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scan Element Type
CMOS / CIS
Light Source
RGB LED array
Max Supported Document Size
300 x 432 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
80 ppm (mono) / 80 ppm (colour)
Max Document Size
300 mm x 3000 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
10000 scans per day
AC 230V ( 50/60 Hz )
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
39.8 cm x 31.2 cm x 19.1 cm
10.5 kg
Environmental Standards
ENERGY STAR Qualified
2 Years
Interface Type
USB 2.0, SCSI
300 x 432 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
80 ppm
Max Document Scan Speed Colour
80 ppm
Duty Cycle
10000 scans per day
Scanner Speed Details
80 ppm - landscape greyscale - 200 dpi , 160 ipm - duplex - landscape greyscale - 200 dpi , 80 ppm - landscape B&W - 200 dpi , 160 ipm - duplex - landscape B&W - 200 dpi , 80 ppm - landscape colour - 200 dpi , 160 ipm - landscape colour - 200 dpi , 80 ppm - landscape colour - 300 dpi , 80 ipm - duplex - landscape colour - 300 dpi , 80 ppm - landscape greyscale - 300 dpi , 130 ipm - duplex - landscape greyscale - 300 dpi , 80 ppm - landscape B&W - 300 dpi , 130 ipm - duplex - landscape B&W - 300 dpi , 60 ppm - portrait greyscale - 200 dpi , 60 ppm - portrait greyscale - 300 dpi , 60 ppm - portrait B&W - 200 dpi , 60 ppm - portrait B&W - 300 dpi , 120 ipm - duplex - portrait greyscale - 200 dpi , 120 ipm - duplex - portrait greyscale - 300 dpi , 120 ipm - duplex - portrait B&W - 200 dpi , 120 ipm - duplex - portrait B&W - 300 dpi , 60 ppm - portrait colour - 200 dpi , 120 ipm - duplex - portrait colour - 200 dpi , 60 ppm - portrait colour - 300 dpi , 80 ipm - duplex - portrait colour - 300 dpi
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection
TWAIN, ISIS
Media Handling
Max Document Size
300 mm x 3000 mm
Plain paper
Automatic
100 sheets
Ultra SCSI , USB 2.0 - Type B
RoHS
Internal power supply
AC 220-240V
Power Consumption Operational (Standby)
38.1 Watt
Software Included
Drivers & Utilities, Adobe Acrobat 9 Standard, Kofax VirtualReScan Basic, Canon CapturePerfect 3.0
39.8 cm
31.2 cm
19.1 cm
10.5 kg
10 °C
32.5 °C
20 - 80%
Service and Support
2 Years
Interface: USB 2.0
Interface: SCSI
Compatibility: PC
Brand: Canon
Price Range Ex VAT: £1500+
