Canon i-SENYS MF4410 A4 Mono Multifunction Laser Printer
Quicklinx: 7HP1WS00 Mfr#: 4509B071AA
This stylish mono laser 3-in-1 offers print, copy and scan functions in one compact device. Ideal for homes and small offices, it's productive, easy-to-use and energy efficient.
  • Stylish and compact
    Offering excellent value for money, this sleek multifunctional provides high quality print, copy and scan functionality in one space saving unit. With its stylish design, it looks great on any desk and is perfect for both home and small office use.
  • Superior image quality
    An enhanced print resolution of up to 1200 x 600 dpi delivers professional laser output for all your work, with sharp text and fine graphics.
  • Easy to use
    The i-SENSYS MF4410 features a simple and intuitive LCD interface designed for easy operation. With 5 lines of text plus animations, features can be quickly and easily accessed and more information can be communicated saving time and effort.
  • Time saving and efficient
    With an output speed of 23 ppm and a fast first copy out time of less than 9 seconds, prints and copies are delivered the moment you need them. With quick recovery from sleep mode, thanks to quick first-print technologies, long waits for your documents are a thing of the past. Additionally, this economical device uses only 3 watts in sleep mode, ensuring energy efficiency.
  • Versatile color scanning
    Scanning color documents and photos is easy and highly versatile using a resolution as high as 9600 x 9600 dpi. Files can be scanned directly to email, or searchable PDF using the MF toolbox, enabling them to be quickly retrieved in the future.
Canon i-SENSYS MF4410 - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 impressions
Max Copying Speed
Up to 23 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 23 ppm
Max Printing Resolution
Up to 1200 x 600 dpi
Scanning
600 x 600 dpi
Original Size
216 mm width (max)
Media Size
76 x 127 mm (min) - 216 x 356 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, heavy-weight paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0
AC 230 V (50/60Hz)
39 cm x 41.4 cm x 30.1 cm
10.3 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - monochrome
8000 impressions
Display
5 lines
USB 2.0
Standard Memory
64 MB 64 MB
Copying
Max Copying Speed
Up to 23 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Up to 23 ppm
Printer Drivers / Emulations
UFRII LT
Image Enhancement Technology
Automatic Image Refinement
First Print Out Time B/W
6 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Max Original Size
216 mm width
Min Media Size
76 x 127 mm
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
250 sheets
100 sheets
Paper cassette - 250 sheets size: 76 x 210 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Copying: up to 23 ppm (A4) - B/W , Printing: up to 23 ppm (A4) - B/W
1 x USB 2.0
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.4.9 - 10.6.x
Software Included
Drivers & Utilities, Presto! PageManager
AC 230 V (50/60Hz)
1220 Watt
Power Consumption Sleep
3 Watt
Warm-Up Time
10 sec
First Copy Out Time B/W
9 sec
Consumables Included
1 x toner cartridge (black) - up to 2100 pages - Canon 728
ENERGY STAR Certified
39 cm
41.4 cm
30.1 cm
10.3 kg
Sound Emission
43 dB (operating)
10 °C
30 °C
20 - 80%
7HP1 Canon MF4410 BLACK TONER In Stock £59.78
