Enhance communications with high quality color output, powerful SEND functionality and auto duplexing. This robust color multifunctional printer is ideal for corporate and small business workgroups.
Give your work added impact with beautiful color images, bold graphics and sharp text. This desktop model incorporates many of the advanced technologies found in Canon's high-end imaging devices to deliver the finest color quality.
With Canon's Quick First-Print technologies there's zero warm-up time, so no waiting. The unit springs into action the moment it's needed. And with up to 21 ppm color print or copy speeds, there's also no waiting for jobs to complete. The i-SENSYS MF9130 is Energy Star certified and consumes only 1.2 watts in sleep mode.
The large 3.5 inch color TFT display with Easy-Scroll Wheel allows easy access to all functions. A target-orientated graphical menu enables speedy, smooth operation.
- Canon i-SENSYS MF9130 - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 65000 impressions
- Max Copying Speed
- Up to 21 ppm (mono) / up to 21 ppm (colour)
- Max Copying Resolution
- 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- 2400 x 600 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 3.5"
- Original Size
- 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 50 sheets
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying)
- Connection Availability
- Interface
- USB 2.0, LAN
- Office Machine Features
- Print from memory card
- Power
- AC 230 V (50/60Hz)
- 54.6 cm x 52.7 cm x 63.2 cm
- 44 kg
- Environmental Standards
- ENERGY STAR Qualified
- Copier Type
- Digital
- Laser - colour
- 65000 impressions
- Display Diagonal Size
- 3.5"
- Interface
- USB 2.0, LAN
- Standard Memory
- 512 MB 512 MB
- Supported Flash Memory
- Memory Stick, CompactFlash, SD Memory Card, Memory Stick PRO, USB flash drive, IBM Microdrive, SDHC Memory Card
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 200%
- Max Document Reduction
- 50%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save, 2 on 1, 4 on 1
Printing
- Printer Drivers / Emulations
- PCL 6, PCL 5c, UFRII LT
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Min Original Size
- 76 x 127 mm
- Max Original Size
- 50 sheets
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 176 g/m²
- Supported Media Type
- 350 sheets
- 850 sheets
- 100 sheets
- 250 sheets
- Paper cassette - 250 sheets , ADF - 50 sheets , Bypass tray - 100 sheets , Output tray - 250 sheets
- Speed Details
- Copying: up to 21 ppm (A4) - colour , Printing: up to 21 ppm (A4) - colour , Copying: up to 21 ppm (A4) - B/W , Printing: up to 21 ppm (A4) - B/W
- 1 x USB 2.0 , 1 x LAN
- Operating System Support
- MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows Vista, Apple Mac OS X 10.2.8 - 10.5.x, MS Windows Server 2008
- Software Included
- Drivers & Utilities
- Voltage Required
- Warm-Up Time
- 60 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages , 1 x toner cartridge (cyan) - up to 6000 pages , 1 x toner cartridge (magenta) - up to 6000 pages , 1 x toner cartridge (yellow) - up to 6000 pages
- ENERGY STAR Certified
- 54.6 cm
- 52.7 cm
- 63.2 cm
- 44 kg
- 10 °C
- 32 °C
- 20 - 80%
