There's no shortage of ways to connect with the i-SENSYS MF8550Cdn, whether it's from the desk, mobile, tablet or the cloud. Built-in Apple AirPrint support automatically detects the printer for printing documents direct from the iPhone or iPad. Canon's free mobile printing app also prints wirelessly to the printer from your Apple iOS device. Wherever your users are they can print to the all-in-one, via the Internet, using Google cloud print.
The i-SENSYS MF8550Cdn is network-ready and integrates seamlessly into your business operations through its support for the industry-standard PCL5c/6. The i-SENSYS MF8550Cdn brings fast, more productive working. Both color and mono documents print and copy at 20 pages per minute, supported by a 50-sheet duplex automatic document feeder. Canon's Quick First-Print technologies and a fast first copy out time mean there's little time lost waiting for output.
Designed for easy operation, one-touch solution keys simplify access to frequently used features, including quick scanning direct to your PC; eco-copying for combining several pages into a single print-out to save paper and money; and secure print for protecting confidential documents and reducing waste by cutting the number of unwanted prints. The all-in-one cartridge simplifies maintenance and increases reliability.
Save time and work more effectively by distributing your documents using Canon's SEND functionality. This scans and sends documents direct to email, a network folder or a USB memory key. For greater flexibility, scanned documents can be sent by email to users' smartphones and tablets and then printed to the i-SENSYS MF8550Cdn using mobile printing.
Canon's On-Demand fixing technology saves you time and money without compromising on performance. ENERGY STAR compliant, the i-SENSYS MF8550Cdn has a market-leading low energy consumption of just 1 W in sleep mode.
Productive, space-saving all-in-one
Increase productivity with this easily shared multifunctional, which fits seamlessly into your network and supports mobile printing. Easy-to-use, the clear 7-line color screen displays all the information users need. The all-in-one combines automatic double-sided printing, copying, scanning and faxing. -
Simple sharing
There's no shortage of ways to connect with the i-SENSYS MF8550Cdn, whether it's from the desk, mobile, tablet or the cloud. Built-in Apple AirPrint support automatically detects the printer for printing documents direct from the iPhone or iPad. Canon's free mobile printing app also prints wirelessly to the printer from your Apple iOS device. Wherever your users are they can print to the all-in-one, via the Internet, using Google cloud print. -
Flexible connectivity
The i-SENSYS MF8550Cdn is network-ready and integrates seamlessly into your business operations through its support for the industry-standard PCL5c/6. -
Speedy and time-saving
The i-SENSYS MF8550Cdn brings fast, more productive working. Both color and mono documents print and copy at 20 pages per minute, supported by a 50-sheet duplex automatic document feeder. Canon's Quick First-Print technologies and a fast first copy out time mean there's little time lost waiting for output. -
User-friendly
Designed for easy operation, one-touch solution keys simplify access to frequently used features, including quick scanning direct to your PC; eco-copying for combining several pages into a single print-out to save paper and money; and secure print for protecting confidential documents and reducing waste by cutting the number of unwanted prints. The all-in-one cartridge simplifies maintenance and increases reliability. -
Versatile document sharing
Save time and work more effectively by distributing your documents using Canon's SEND functionality. This scans and sends documents direct to email, a network folder or a USB memory key. For greater flexibility, scanned documents can be sent by email to users' smartphones and tablets and then printed to the i-SENSYS MF8550Cdn using mobile printing. -
Save energy and money
- Canon i-SENSYS MF8550Cdn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 impressions
- Max Copying Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Display
- 3.5"
- Original Size
- 128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, coated paper, heavy-weight paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 125 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Document send function, save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50/60Hz)
- 43 cm x 48.4 cm x 47.9 cm
- 31 kg
- Environmental Standards
- ENERGY STAR Qualified
- 2 Years
- Fax Type
- Plain paper
- Laser - colour
- 40000 impressions
- Display
- 7 lines
- Display Diagonal Size
- 3.5"
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PCL 5c, UFRII LT
- First Print Out Time B/W
- 14.5 sec
- First Print Out Time Colour
- 14.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 512 pages
- Handset
- Optional
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 181 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 210 stations
- Fax forwarding, activity report, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access
Document & Media Handling
- Min Original Size
- 128 x 139.7 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 300 sheets
- 50 sheets
- 125 sheets
- ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 125 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - colour , Printing: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - colour , Copying: up to 20 ppm (A4) - B/W
- 1 x USB 2.0 , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- Operating System Support
- MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8
- Software Included
- Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
- Voltage Required
- 1200 Watt
- Power Consumption Standby
- 23 Watt
- Power Consumption Sleep
- 1 Watt
- Warm-Up Time
- 23 sec
- First Copy Out Time B/W
- 15.5 sec
- First Copy Out Time Colour
- 16.2 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages - Canon 718 Starter , 1 x toner cartridge (cyan) - up to 1400 pages - Canon 718 Starter , 1 x toner cartridge (magenta) - up to 1400 pages - Canon 718 Starter , 1 x toner cartridge (yellow) - up to 1400 pages - Canon 718 Starter
- ENERGY STAR Certified
- 43 cm
- 48.4 cm
- 47.9 cm
- 31 kg
- Sound Emission
- 50.3 dBA (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
Service and Support
- 2 Years
