Benefit from high performance and professional color quality - boost your business productivity with this space and energy saving unit.
This high performance multifunctional combines style and space-saving simplicity. It's clean, uncomplicated design - with smooth, curved lines - ensures ease of use and easy placement as well as exceptional color convenience.
Canon's advanced color imaging technologies give you a competitive edge, delivering faithful color reproduction as well as sharp black text. Create high impact marketing materials thanks to these innovative technologies, S-Toner and Automatic Image Refinement (AIR) for up to 2400 x 600 dpi printing.
The easy-to-use, backlit, 5-line LCD display with intuitive menus and animated troubleshooting makes operation effortless straight from the start. Canon's all-in-one cartridge system provides maintenance-free operation, consistently high quality output and the convenience of fewer consumables.
Art of simplicity
This high performance multifunctional combines style and space-saving simplicity. It's clean, uncomplicated design - with smooth, curved lines - ensures ease of use and easy placement as well as exceptional color convenience. -
Superior color quality
Canon's advanced color imaging technologies give you a competitive edge, delivering faithful color reproduction as well as sharp black text. Create high impact marketing materials thanks to these innovative technologies, S-Toner and Automatic Image Refinement (AIR) for up to 2400 x 600 dpi printing. -
Accelerate productivity
A rapid 20ppm/cpm output speed in color and mono brings high volume printing to small and medium size businesses. Automatic double-sided printing as standard, a fast first copy out time of just 16 seconds or less (color and mono) and the 50-sheet Automatic Document Feeder accelerate productivity. Print and copy straight away from sleep mode thanks to Quick First-Print technologies. -
Cut costs, save energy
Cut your paper costs with automatic double sided printing. Reduce your running costs too, as this energy efficient multifunctional is Energy Star certified and consumes only 3 watts in sleep mode. -
Superior color scanning
Produce superb color scans in a few simple steps, including scanning over the network or directly to a USB memory key. Scan into a number of digital formats including compressed PDF files that are perfect for emailing and sharing. Canon's compression technology reduces the file size without compromising image quality. -
Easy to use
The easy-to-use, backlit, 5-line LCD display with intuitive menus and animated troubleshooting makes operation effortless straight from the start. Canon's all-in-one cartridge system provides maintenance-free operation, consistently high quality output and the convenience of fewer consumables. -
Network ready
Small workgroups can share functionality. The remote user interface lets users and administrators remotely monitor and manage machine status over the network. Department ID management safeguards important settings, prevents unauthorized access to the machine's functionality and enables strict control of costs.
- Canon i-SENSYS MF8330CDN - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 impressions
- Max Copying Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- 2400 x 600 dpi (colour)
- Scanning
- 600 x 600 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, coated paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 125 sheets
- Connection Availability
- Interface
- USB 2.0, LAN
- Power
- AC 230 V (50/60Hz)
- 67.4 cm x 133 cm x 85.1 cm
- 31 kg
- Environmental Standards
- ENERGY STAR Qualified
- Copier Type
- Digital
- Laser - colour
- 40000 impressions
- Display
- 5 lines
- Interface
- USB 2.0, LAN
- Standard Memory
- 128 MB 128 MB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy
Printing
- Printer Drivers / Emulations
- UFRII LT
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- Legal
- Min Media Weight
- 50 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- 300 sheets
- 50 sheets
- 125 sheets
- ADF - 50 sheets weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets weight: 60 g/m² - 163 g/m² , Output tray - 125 sheets , Bypass tray - 50 sheets weight: 60 g/m² - 220 g/m²
- Speed Details
- Copying: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - colour , Printing: up to 20 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour
- 1 x USB 2.0 , 1 x LAN
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows Server 2003, MS Windows Vista, MS Windows Server 2008, Apple MacOS X 10.4.9 or later
- Software Included
- Drivers & Utilities, Presto! PageManager
- Voltage Required
- 1200 Watt
- Power Consumption Standby
- 25 Watt
- Power Consumption Sleep
- 3 Watt
- Warm-Up Time
- 23 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3400 pages - Canon 718 Starter , 1 x toner cartridge (cyan) - up to 2900 pages - Canon 718 Starter , 1 x toner cartridge (magenta) - up to 2900 pages - Canon 718 Starter , 1 x toner cartridge (yellow) - up to 2900 pages - Canon 718 Starter
- ENERGY STAR Certified
- 67.4 cm
- 133 cm
- 85.1 cm
- 31 kg
- Sound Emission
- 46 dB (idle) / 67 dB (operating)
- 10 °C
- 30 °C
- 20 - 80%
Canon 718 Black Toner | In Stock | £90.23 |
