Print, copy, scan and fax faster than ever before, with an all-in-one color laser printer optimized for seamless working, whether in or out of the office. Fast and flexible working with enhanced collaboration boosts productivity, wherever you are. Move securely between working environments with customized controls, advanced connectivity and an intuitive user experience.
Optimized productivity
Streamline process efficiency, with rapid print and scan speeds, small media support and centralized print management through Microsoft Universal Print. -
Intuitive user experience
Expert user control is easy thanks to natural workflows and one-touch commands on the large 17.8cm/7-inch LCD touchscreen display. -
Enhanced connectivity
Stay connected for the ultimate collaboration and productivity, with mobile apps and dual network capability.
- Canon i-SENSYS MF832Cdw - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 pages
- Max Copying Speed
- Up to 38 ppm (mono) / up to 38 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- 48 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, coated paper, heavy-weight paper, thin paper, postcards, coloured paper, prepunched paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 2300 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 200 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to Cloud, wireless direct printing, scan to FTP, Push Scan, Pull Scan, scan to PC, iFAX
- Power
- AC 230 V (50/60Hz)
- 50 cm x 55.6 cm x 64 cm
- 41 kg
- 2-year warranty (France - 3 years with product registration)
- Printer Fonts
- PCL x 93 , PostScript x 136
- Fax Type
- Plain paper
- Laser - colour
- 80000 pages
- 2000 pages
- Display Diagonal Size
- 7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 2 GB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- Toner Save, ID Card Copy, Preset Reduction/Enlargement Ratios, Sort, Frame Erase Copy, Job Build, blank page skipping, adjustable copy density, N-in-1, interrupt mode
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, TIFF, XPS, UFRII, JPEG
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 30000 pages
- PC Faxing
- Yes (send only)
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 256 stations
- Delayed sending, fax preview
Document & Media Handling
- Min Original Size
- 48 x 128 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 48 x 128 mm
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 216 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 216 x 297 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), 101.6 x 148 mm, Foolscap
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 650 sheets
- 2300 sheets
- 100 sheets
- 200 sheets
- ADF - 100 sheets size: 48 x 128 mm - Legal (216 x 356 mm) weight: 42 g/m² - 128 g/m² , Paper cassette - 550 sheets size: 101.6 x 148 mm - 216 x 297 mm weight: 60 g/m² - 163 g/m² , Multi-purpose tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 200 sheets
- Speed Details
- Printing: up to 38 ppm (A4) - colour , Printing: up to 38 ppm (A4) - B/W , Printing: up to 59 ppm (A5) - colour , Printing: up to 59 ppm (A5) - B/W , Copying: up to 38 ppm (A4) - B/W , Copying: up to 38 ppm (A4) - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Secure Print, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering, Wi-Fi Direct, SNMP 3
- Operating System Support
- MS Windows Server 2012, Windows 8.1, MS Windows Server 2012 R2, Windows 10, MS Windows Server 2016, Apple Mac OS X 10.11 or later, MS Windows Server 2019
- Software Included
- Drivers & Utilities, iW Enterprise Management Console
- Voltage Required
- 1500 Watt
- Power Consumption Standby
- 33.3 Watt
- Power Consumption Sleep
- 1.1 Watt
- Warm-Up Time
- 12 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages - Canon 064 Starter , 1 x toner cartridge (cyan) - up to 3200 pages - Canon 064 Starter , 1 x toner cartridge (magenta) - up to 3200 pages - Canon 064 Starter , 1 x toner cartridge (yellow) - up to 3200 pages - Canon 064 Starter
- Limited warranty - 2 years
- Regional Warranty Exceptions
- France - 3 years with product registration
- 50 cm
- 55.6 cm
- 64 cm
- 41 kg
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
