Canon I-SENSYS MF8040CN MFP 2400X600
Quicklinx: 83SLWS00 Mfr#: 5119B028AA
Convenient and easy to use this stylish all-in-one, with a modern design, offers excellent color quality for small businesses. Network-ready, the multifunctional device makes it simple to share full color printing, copying and scanning across small workgroups, boosting productivity.
Canon's advanced imaging technologies faithfully reproduce vibrant colors and deliver sharp, black text that enable you to make an immediate impact with high-quality output. Automatic image refinement delivers up to 2400 x 600 dpi printing. The i-SENSYS MF8040Cn prints and copies at 8 pages per minute (ppm) in color and 12 ppm mono. To accelerate workflows within small workgroups there is a 50-sheet automatic document feeder and little time is lost waiting for output with a quick first copy out time. With Canon's Quick First-Print technologies, there's also minimal delay on printing and copying straight from sleep mode.
  • Compact, color all-in-one
  • Superior quality output
  • Simple to operate
    For extreme ease of use, conveniently-placed one touch solution keys enable an even greater user experience. These give direct access to key features including quick scanning direct to your PC and eco-copying, which combines several pages into a single print out, reducing paper usage and saving costs.
  • User-friendly
    All the essential information needed to operate the machine is shown on the clear, backlit 5-line LCD display. Intuitive menus allow users to work more productively and navigate between different functions quickly - including features like scan to USB, which make document distribution easier.
  • Lower running costs
    Save energy and cut your costs, along with your carbon footprint. The energy-efficient i-SENSYS MF8040Cn is ENERGY STAR certified with low Typical Energy Consumption (TEC). Canon's On-Demand fixing technology also means it has low energy consumption in sleep mode.
Canon i-SENSYS MF8040Cn - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 impressions
Max Copying Speed
Up to 12 ppm (mono) / up to 8 ppm (colour)
Max Copying Resolution
600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
2400 x 600 dpi (colour)
Scanning
600 x 600 dpi
Original Size
128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, coated paper, heavy-weight paper
Standard Media Capacity
150 sheets
Output Trays Capacity
125 sheets
Connection Availability
USB 2.0, LAN, USB host
Office Machine Features
Save to USB flash drive
AC 230 V (50/60Hz)
43 cm x 48.4 cm x 42.9 cm
26 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - colour
30000 impressions
Display
5 lines
Standard Memory
128 MB 128 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
UFRII LT
Image Enhancement Technology
Automatic Image Refinement
First Print Out Time B/W
22 sec
First Print Out Time Colour
28.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Min Original Size
128 x 139.7 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
150 sheets
125 sheets
ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 125 sheets
Speed Details
Printing: up to 8 ppm (A4) - colour , Printing: up to 12 ppm (A4) - B/W , Copying: up to 8 ppm (A4) - colour , Copying: up to 12 ppm (A4) - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.4.9 - 10.7.x
Software Included
Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
AC 230 V (50/60Hz)
900 Watt
Power Consumption Standby
15 Watt
Power Consumption Sleep
2.2 Watt
Warm-Up Time
30 sec
First Copy Out Time B/W
22.5 sec
First Copy Out Time Colour
29.3 sec
Consumables Included
1 x toner cartridge (black) - up to 800 pages - Canon 716 Starter , 1 x toner cartridge (cyan) - up to 800 pages - Canon 716 Starter , 1 x toner cartridge (magenta) - up to 800 pages - Canon 716 Starter , 1 x toner cartridge (yellow) - up to 800 pages - Canon 716 Starter
ENERGY STAR Certified
43 cm
48.4 cm
42.9 cm
26 kg
Sound Emission
43 dB (idle) / 63.4 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
83SL Canon 716 Cyan Toner for LBP5050 In Stock £52.59
83SL Canon 716 Yellow Toner for LBP5050 In Stock £52.59
