Canon i-SENSYS MF752Cdw A4 Colour MFP Laser
Quicklinx: HYZNWS00 Mfr#: 5455C017
14 In Stock
£298.27 ex VAT
£357.92 inc VAT
An updated color engine in the Canon i-SENSYS MF750 series delivers advanced usability and connectivity capabilities, as well as fast print and scan speeds, to boost your business productivity.
  • Streamline everyday business tasks
  • Ultimate productivity
    Work faster by printing and scanning at speeds of up to 33 ppm and 100 ipm (A4), as well as utilizing a wide range of media handling with the ability to scan small documents such as checks and receipts.
  • Built-in cloud connectivity
    Centralize print management with cloud-based universal print by Microsoft and access documents directly from cloud storage services: Google Drive, DropBox and OneDrive.
  • Intuitive user experience
    Streamline workflows with drag and drop tabs to customize the display and create one-touch shortcut buttons with application library apps.
  • Reliable security
    Advanced system verification protects the device from hacking and virus threats as soon as you start up, while secure PIN restricts access to sensitive documents.
Canon i-SENSYS MF752Cdw - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 33 ppm (mono) / up to 33 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Original Size
A6 (105 x 148 mm) (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, coated paper, heavy-weight paper, thin paper, postcards, coloured paper, prepunched paper
Standard Media Capacity
250 sheets
Max Media Capacity
900 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to Cloud, scan to FTP, scan to PC, scan to USB host
AC 230 V (50/60Hz)
42.5 cm x 46.1 cm x 43 cm
23.3 kg
Printer Fonts
PCL x 45
Printing Technology
Laser - colour
50000 pages
750 - 4000 pages
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, text / photo / map
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy, reserve copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PCL 5c, PDF, TIFF, UFRII, JPEG
First Print Out Time B/W
7.1 sec
First Print Out Time Colour
7.1 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Grayscale Depth
16-bit
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
Supported Original Sizes
Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, 98 x 148 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
Max Media Capacity
900 sheets
50 sheets
150 sheets
Paper cassette - 250 sheets size: 98 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Multi-purpose tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , ADF - 50 sheets size: 48 x 85 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 33 ppm (A4) - B/W , Printing: up to 33 ppm (A4) - colour , Copying: up to 33 ppm (A4) - B/W , Copying: up to 33 ppm (A4) - colour , Copying: up to 29 ipm (A4) - B/W duplex , Copying: up to 29 ipm (A4) - colour duplex , Scanning: up to 50 ipm - B/W , Scanning: up to 40 ipm - colour , Scanning: up to 100 ipm - B/W duplex , Scanning: up to 80 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Secure Print, SSL, WEP, WPA-PSK, IPsec, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, SNMP 3, WPA2-EAP, TLS 1.3 Encryption
Operating System Support
Linux, Apple MacOS X 10.2 or later, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, MS Windows Server 2016, MS Windows Server 2019, Windows 11, MS Windows Server 2022
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
1380 Watt
Power Consumption Standby
24 Watt
Power Consumption Sleep
1 Watt
First Copy Out Time B/W
7.6 sec
First Copy Out Time Colour
8.8 sec
Consumables Included
1 x toner cartridge (black) - up to 2100 pages - Canon 069 Starter , 1 x toner cartridge (cyan) - up to 1100 pages - Canon 069 Starter , 1 x toner cartridge (magenta) - up to 1100 pages - Canon 069 Starter , 1 x toner cartridge (yellow) - up to 1100 pages - Canon 069 Starter
42.5 cm
46.1 cm
43 cm
23.3 kg
Sound Emission
29 dBA (idle)
10 °C
30 °C
20 - 80% (non-condensing)
Brand: Canon
