Canon i-SENSYS MF746Cx Colour Laser Multifunction Printer
Quicklinx: FRZMWS00 Mfr#: 3101C022
Canon's i-SENSYS MF746Cx multifunction color printer with fax as well as versatile print control options offers extensive security and cost management options.
Canon i-SENSYS MF746Cx - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards, coloured paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, access point mode, scan to PC, scan to USB host, iFAX
AC 230 V (50/60Hz)
47.1 cm x 46.9 cm x 46 cm
26.7 kg
Printer Fonts
PCL x 93 , PostScript x 136
Fax Type
Plain paper
Printing Technology
Laser - colour
50000 pages
750 - 4000 pages
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, text / photo / map
Automatic Duplexing
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
7.7 sec
First Print Out Time Colour
8.6 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 512 pages
PC Faxing
Yes (send only)
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
281 station(s)
Telephone / Fax Switch
Broadcast Transmission
310 stations
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, Double Sided Faxing, fax memory backup, fax activity reports
Document & Media Handling
Min Original Size
128 x 139.7 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 128 x 139.7 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 148 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
300 sheets
50 sheets
150 sheets
Paper cassette - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 27 ppm (A4) , Printing: up to 49 ppm (A5) , Printing: up to 24.5 ipm (A4) - colour duplex , Printing: up to 24.5 ipm (A4) - B/W duplex , Copying: up to 27 ppm (A4) , Copying: up to 21.9 ipm (A4) - B/W duplex , Copying: up to 21.9 ipm (A4) - colour duplex , Scanning: up to 27 ipm - B/W , Scanning: up to 14 ipm - colour , Scanning: up to 27 ipm - colour duplex , Scanning: up to 47 ipm - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, ARP, MAC address filtering, IPv6 support, SNMP 3
Operating System Support
Linux, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14 or later
Software Included
Drivers & Utilities, iW Management Console
AC 230 V (50/60Hz)
1390 Watt
Power Consumption Standby
18 Watt
Power Consumption Sleep
0.7 Watt
Warm-Up Time
13 sec
First Copy Out Time B/W
10.2 sec
First Copy Out Time Colour
12 sec
Consumables Included
1 x toner cartridge (black) - up to 2300 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages
47.1 cm
46.9 cm
46 cm
26.7 kg
Sound Emission
26 dBA (idle) / 50 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
FRZM Canon 055H High Yield Ink Cartridge - Yellow In Stock £150.89
FRZM Canon 055H High Yield Ink Cartridge - Magenta In Stock £150.89
FRZM Canon 055H High Yield Ink Cartridge - Cyan In Stock £150.89
FRZM Canon 055H High Yield Ink Cartridge - Black In Stock £109.73
