Canon's i-SENSYS MF746Cx multifunction color printer with fax as well as versatile print control options offers extensive security and cost management options.
- Canon i-SENSYS MF746Cx - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Speed
- Up to 27 ppm (mono) / up to 27 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards, coloured paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, access point mode, scan to PC, scan to USB host, iFAX
- Power
- AC 230 V (50/60Hz)
- 47.1 cm x 46.9 cm x 46 cm
- 26.7 kg
- Printer Fonts
- PCL x 93 , PostScript x 136
- Fax Type
- Plain paper
- Laser - colour
- 50000 pages
- 750 - 4000 pages
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, text / photo / map
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, TIFF, UFRII, JPEG
- First Print Out Time B/W
- 7.7 sec
- First Print Out Time Colour
- 8.6 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 512 pages
- PC Faxing
- Yes (send only)
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 281 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 310 stations
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, Double Sided Faxing, fax memory backup, fax activity reports
Document & Media Handling
- Min Original Size
- 128 x 139.7 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 128 x 139.7 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 148 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 300 sheets
- 50 sheets
- 150 sheets
- Paper cassette - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 27 ppm (A4) , Printing: up to 49 ppm (A5) , Printing: up to 24.5 ipm (A4) - colour duplex , Printing: up to 24.5 ipm (A4) - B/W duplex , Copying: up to 27 ppm (A4) , Copying: up to 21.9 ipm (A4) - B/W duplex , Copying: up to 21.9 ipm (A4) - colour duplex , Scanning: up to 27 ipm - B/W , Scanning: up to 14 ipm - colour , Scanning: up to 27 ipm - colour duplex , Scanning: up to 47 ipm - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Secure Print, SSL, Apple Bonjour, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, ARP, MAC address filtering, IPv6 support, SNMP 3
- Operating System Support
- Linux, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14 or later
- Software Included
- Drivers & Utilities, iW Management Console
- Voltage Required
- 1390 Watt
- Power Consumption Standby
- 18 Watt
- Power Consumption Sleep
- 0.7 Watt
- Warm-Up Time
- 13 sec
- First Copy Out Time B/W
- 10.2 sec
- First Copy Out Time Colour
- 12 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 2300 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages
- 47.1 cm
- 46.9 cm
- 46 cm
- 26.7 kg
- Sound Emission
- 26 dBA (idle) / 50 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
Canon 055H High Yield Ink Cartridge - Yellow | In Stock | £151.87 |
Canon 055H High Yield Ink Cartridge - Magenta | In Stock | £150.89 |
Canon 055H High Yield Ink Cartridge - Cyan | In Stock | £151.87 |
Canon 055H High Yield Ink Cartridge - Black | In Stock | £110.44 |
