Canon i-SENSYS MF742Cdw Colour Laser Multifunction Printer
Quicklinx: FRZLWS00 Mfr#: 3101C034
Canon's i-SENSYS MF742Cdw multifunction color printer will help small and medium business owners and take productivity to new levels.
This multi-function colour laser printer has a wealth of features to help small and medium-sized businesses work efficiently. Delivering up to 27 A4 pages per minute and 47 scans per minute, this printer also uses automatic double-sided printing to reduce the amount of paper used. Users can tailor their LCD display to the needs of their office by creating shortcuts to regularly printed documents, forms or specific copy settings, and using the Canon PRINT Business app you can print wirelessly and securely from a smartphone or tablet.
  • Efficient connectivity
    With a suite of connectivity options including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi(n), alongside mobile printing capabilities like Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any workflow.
  • Advanced security
    Equipped with robust security protocols such as 802.1x, AES, IP filtering, MAC address filtering, SNMP 3, SSL, Secure Print, TKIP, WEP, WPA-PSK, and WPA2-PSK, the Canon i-SENSYS MF742Cdw safeguards sensitive information, ensuring peace of mind for users.
  • High-quality printing and copying
    Achieve high-quality prints and copies with up to 1200 x 1200 DPI resolution, automatic duplexing for efficient paper usage, and fast output speeds of 27 ppm for both black and white and color documents.
  • Versatile media handling
    This printer accommodates a wide range of media sizes and types, including envelopes, glossy paper, heavy-weight paper, labels, and more, making it ideal for diverse printing needs.
  • Convenient scanning features
    With a color depth of 24-bit and an interpolated resolution of up to 9600 x 9600 DPI, scanning documents is both detailed and versatile, supporting a variety of document sizes and types.
Canon i-SENSYS MF742Cdw - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Original Size
128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards, coloured paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, access point mode, scan to PC, scan to USB host
AC 230 V (50/60Hz)
47.1 cm x 46.9 cm x 46 cm
26.7 kg
2-year warranty (France - 3 years with product registration)
Printer Fonts
PCL x 45
Printing Technology
Laser - colour
50000 pages
750 - 4000 pages
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, text / photo / map
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PCL 5c, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
7.7 sec
First Print Out Time Colour
8.6 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Min Original Size
128 x 139.7 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 128 x 139.7 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 148 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
300 sheets
50 sheets
150 sheets
Paper cassette - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 27 ppm (A4) , Printing: up to 49 ppm (A5) , Copying: up to 27 ppm (A4) , Scanning: up to 27 ipm - B/W , Scanning: up to 14 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, ARP, MAC address filtering, IPv6 support, SNMP 3
Operating System Support
Linux, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14 or later
Software Included
Drivers & Utilities, iW Management Console
AC 230 V (50/60Hz)
1390 Watt
Power Consumption Standby
18 Watt
Power Consumption Sleep
0.7 Watt
Warm-Up Time
13 sec
First Copy Out Time B/W
10.2 sec
First Copy Out Time Colour
12 sec
Consumables Included
1 x toner cartridge (black) - up to 2300 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages
Regional Warranty Exceptions
47.1 cm
46.9 cm
46 cm
26.7 kg
Sound Emission
28 dBA (idle) / 50 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
FRZL Canon 055H High Yield Ink Cartridge - Cyan In Stock £149.31
FRZL Canon 055H High Yield Ink Cartridge - Black In Stock £108.60
