Canon i-SENSYS MF732Cdw Colour Laser Multifunction Printer
Quicklinx: D0XMWS00 Mfr#: 1474C068
This color laser multifunctional delivers a comprehensive solution for SMEs. Convenient features such as quick single-pass two-sided scanning, a color touchscreen and speedy duplex printing combine to boost productivity.
  • Efficient connectivity
    With a wide range of connectivity options including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi, alongside mobile printing capabilities like Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any workflow.
  • Advanced security
    Equipped with robust security protocols such as 802.1x, IP filtering, MAC address filtering, Secure Print, WEP, WPA-PSK, and WPA2-PSK, the Canon i-SENSYS MF732Cdw safeguards sensitive documents and maintains privacy.
  • High-quality copying
    Featuring a maximum copying resolution of 600 x 600 DPI for both black and white and color, along with versatile copying features like 2 on 1, 4 on 1, Frame Erase Copy, ID Card Copy, and Toner Save, this device delivers professional-grade copies efficiently.
  • Versatile media handling
    Supports a broad range of media sizes and types, including envelopes, glossy paper, heavy-weight paper, labels, plain paper, postcards, recycled paper, and thin paper, making it ideal for diverse printing needs.
  • Eco-friendly operation
    ENERGY STAR certified, the Canon i-SENSYS MF732Cdw promotes energy efficiency with a low power consumption in sleep mode and a range of eco-conscious features, aligning with sustainability goals.
Canon i-SENSYS MF732Cdw - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
5"
Original Size
128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to PC, scan to USB host
AC 230 V (50/60Hz)
45.1 cm x 46.9 cm x 46 cm
26.5 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - colour
50000 pages
750 - 4000 pages
Display Diagonal Size
5"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, text / photo / map
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
8.3 sec
First Print Out Time Colour
8.6 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Min Original Size
128 x 139.7 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
52 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 148 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
300 sheets
50 sheets
150 sheets
Paper cassette - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 27 ppm (A4) , Printing: up to 49 ppm (A5) , Copying: up to 27 ppm (A4) , Scanning: up to 27 ipm - B/W , Scanning: up to 14 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering, Wi-Fi Direct
Operating System Support
Linux, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5 or later, Windows 10, MS Windows Server 2016
Software Included
Drivers & Utilities, Presto! PageManager, Canon Print Service Plug-in for Android, iW Management Console, Canon PRINT Business
AC 230 V (50/60Hz)
1.4 kW
Power Consumption Standby
17.7 Watt
Power Consumption Sleep
0.8 Watt
Warm-Up Time
13 sec
First Copy Out Time B/W
11.3 sec
First Copy Out Time Colour
9.8 sec
Consumables Included
1 x toner cartridge (black) - up to 2200 pages - Canon 046 Starter , 1 x toner cartridge (cyan) - up to 1200 pages - Canon 046 Starter , 1 x toner cartridge (magenta) - up to 1200 pages - Canon 046 Starter , 1 x toner cartridge (yellow) - up to 1200 pages - Canon 046 Starter
ISO 9296
ENERGY STAR Certified
45.1 cm
46.9 cm
46 cm
26.5 kg
Sound Emission
28 dB (idle) / 48 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
