Canon i-SENSYS MF643Cdw Colour Laser Multifunction Printer
Quicklinx: FFHHWS00 Mfr#: 3102C035
The all-in-one, Canon Color imageCLASS MF634Cdw offers feature rich capabilities in a high quality, reliable printer that is ideal for any office environment. Print, scan, copy and fax capabilities help you accomplish all necessary tasks with just one machine. Easy to use features such as the intuitive 5-inch color touch LCD panel, various mobile solutions and a single-pass, duplex scan feature, your business will have the support and efficiency it deserves.
  • Efficient connectivity
    With a range of connectivity options including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi(n), alongside mobile printing capabilities like Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any workflow.
  • Advanced security
    Equipped with robust security protocols such as 802.1x, AES, IP filtering, MAC address filtering, SNMP 3, SSL, Secure Print, TKIP, WEP, WPA-PSK, and WPA2-PSK, the Canon i-SENSYS MF643Cdw safeguards sensitive information, ensuring peace of mind.
  • High-quality printing and copying
    Boasting a maximum printing and copying resolution of 600 x 600 DPI for both black and white and color, along with a speed of 21 ppm, this device delivers professional-grade documents swiftly.
  • Versatile media handling
    From envelopes to glossy paper, the Canon i-SENSYS MF643Cdw handles a wide range of media types and sizes, including A4, Legal, and more, making it ideal for diverse printing needs.
  • Convenient scanning features
    Offering a color depth of 24-bit and an interpolated resolution of 9600 x 9600 DPI, the scanner provides high-quality digital copies, while features like scan to Cloud, FTP, PC, USB host, and email enhance productivity.
Canon i-SENSYS MF643Cdw - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2500 pages
Max Copying Speed
Up to 21 ppm (mono) / up to 21 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Original Size
128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards, coloured paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to Cloud, scan to FTP, scan to PC, scan to USB host
AC 230 V (50/60Hz)
45.1 cm x 46 cm x 41.3 cm
22.6 kg
2-year warranty (France - 3 years with product registration)
Printer Fonts
PCL x 45
Printing Technology
Laser - colour
30000 pages
250 - 2500 pages
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, text / photo / map
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
10.4 sec
First Print Out Time Colour
10.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Min Original Size
128 x 139.7 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 128 x 139.7 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
100 sheets
Paper cassette - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Multi-purpose tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 21 ppm (A4) , Copying: up to 21 ppm (A4) , Scanning: up to 14 ipm - colour , Scanning: up to 27 ipm - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, ARP, MAC address filtering, SNMP 3
Operating System Support
Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14
Software Included
Drivers & Utilities, iW Management Console
AC 230 V (50/60Hz)
850 Watt
Power Consumption Standby
11 Watt
Power Consumption Sleep
0.8 Watt
Warm-Up Time
13 sec
Consumables Included
1 x toner cartridge (black) - up to 1500 pages - Canon 054 Starter , 1 x toner cartridge (cyan) - up to 680 pages - Canon 054 Starter , 1 x toner cartridge (magenta) - up to 680 pages - Canon 054 Starter , 1 x toner cartridge (yellow) - up to 680 pages - Canon 054 Starter
Regional Warranty Exceptions
45.1 cm
46 cm
41.3 cm
22.6 kg
Sound Emission
51 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
