The all-in-one, Canon Color imageCLASS MF634Cdw offers feature rich capabilities in a high quality, reliable printer that is ideal for any office environment. Print, scan, copy and fax capabilities help you accomplish all necessary tasks with just one machine. Easy to use features such as the intuitive 5-inch color touch LCD panel, various mobile solutions and a single-pass, duplex scan feature, your business will have the support and efficiency it deserves.
Efficient connectivity
With a range of connectivity options including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi(n), alongside mobile printing capabilities like Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any workflow. -
Advanced security
Equipped with robust security protocols such as 802.1x, AES, IP filtering, MAC address filtering, SNMP 3, SSL, Secure Print, TKIP, WEP, WPA-PSK, and WPA2-PSK, the Canon i-SENSYS MF643Cdw safeguards sensitive information, ensuring peace of mind. -
High-quality printing and copying
Boasting a maximum printing and copying resolution of 600 x 600 DPI for both black and white and color, along with a speed of 21 ppm, this device delivers professional-grade documents swiftly. -
Versatile media handling
From envelopes to glossy paper, the Canon i-SENSYS MF643Cdw handles a wide range of media types and sizes, including A4, Legal, and more, making it ideal for diverse printing needs. -
Convenient scanning features
Offering a color depth of 24-bit and an interpolated resolution of 9600 x 9600 DPI, the scanner provides high-quality digital copies, while features like scan to Cloud, FTP, PC, USB host, and email enhance productivity.
- Canon i-SENSYS MF643Cdw - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Max Copying Speed
- Up to 21 ppm (mono) / up to 21 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Original Size
- 128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards, coloured paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to Cloud, scan to FTP, scan to PC, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 45.1 cm x 46 cm x 41.3 cm
- 22.6 kg
- 2-year warranty (France - 3 years with product registration)
- Printer Fonts
- PCL x 45
- Laser - colour
- 30000 pages
- 250 - 2500 pages
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, text / photo / map
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PDF, TIFF, UFRII, JPEG
- First Print Out Time B/W
- 10.4 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Min Original Size
- 128 x 139.7 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 128 x 139.7 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Paper cassette - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Multi-purpose tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 21 ppm (A4) , Copying: up to 21 ppm (A4) , Scanning: up to 14 ipm - colour , Scanning: up to 27 ipm - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Secure Print, SSL, Apple Bonjour, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, ARP, MAC address filtering, SNMP 3
- Operating System Support
- Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14
- Software Included
- Drivers & Utilities, iW Management Console
- Voltage Required
- 850 Watt
- Power Consumption Standby
- 11 Watt
- Power Consumption Sleep
- 0.8 Watt
- Warm-Up Time
- 13 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1500 pages - Canon 054 Starter , 1 x toner cartridge (cyan) - up to 680 pages - Canon 054 Starter , 1 x toner cartridge (magenta) - up to 680 pages - Canon 054 Starter , 1 x toner cartridge (yellow) - up to 680 pages - Canon 054 Starter
- Limited warranty - 2 years
- Regional Warranty Exceptions
- France - 3 years with product registration
- 45.1 cm
- 46 cm
- 41.3 cm
- 22.6 kg
- Sound Emission
- 51 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
