Get print, scan, copy and fax functionality from one compact printer, perfect for businesses tight on space. With flexible connectivity, rapid printing and intuitive controls, the MF543x will take productivity to another level.
Canon i-SENSYS MF543x in More Detail
Offering print, scan, copy and fax functionality in a compact footprint, the Canon i-SENSYS MF543x is a fast and versatile mono multifunction laser printer that has been designed with hard-working businesses in mind. With fast printing speeds, flexible mobile connectivity and advanced customisable controls, it’s the perfect device for busy small businesses which are looking for a powerful space-saving solution.
Take productivity to another level
The Canon i-SENSYS MF543x is ready to take your team’s productivity to another level. It offers ultra-fast printing speeds of up to 43ppm for single-sided A4 and has a first page out time as fast as 5.7 seconds, meaning you’ll be able to print all your documents quickly and efficiently. In addition, double-sided printing and single-pass double-sided scanning work to further boost your productivity and make it easier to get through larger workloads.
Powerful controls
The large 12.7cm colour touchscreen offers intuitive on-screen controls and makes it easy to operate the functions of the device. Canon’s unique Application Library allows you to tailor on-screen options to suit your individual needs and provides convenient one-touch access to the functions you use every day, like scan to email or printing a saved form.
Versatile connectivity
The Canon i-SENSYS MF543x delivers simple mobile connectivity and offers a variety of versatile connection options, including USB, Network, Wireless and Wi-Fi Direct. There’s also support AirPrint and Mopria, allowing you to print wirelessly from iOS and Android devices with the tap of a button. Meanwhile, NFC pairing enables you to connect Bluetooth devices simply by touching them.
Performance and security
You can rely on the Canon i-SENSYS MF543x to produce high-quality prints time after time. It’s also ideal for handling sensitive documents, with a built-in PIN document release function that holds print jobs until the required PIN is entered into the machine.
Efficient connectivity
With a range of connectivity options including Gigabit Ethernet, NFC, USB 2.0, and Wi-Fi, along with support for Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any workflow. -
Advanced security
Equipped with comprehensive security protocols such as 802.1x, AES, ARP, IP filtering, MAC address filtering, SSL, Secure Print, and more, the Canon i-SENSYS MF543x offers peace of mind with protected document handling. -
High-speed printing and copying
Achieve maximum productivity with fast printing and copying speeds of up to 43 ppm and a quick first print out time of 5.7 sec, complemented by automatic duplexing to save time and paper. -
Versatile media handling
This printer excels in flexibility with a wide range of supported media sizes and types, including envelopes, labels, plain paper, postcards, and recycled paper, making it suitable for various business needs. -
Comprehensive scanning capabilities
The device offers advanced scanning features with automatic duplexing, a high interpolated resolution of up to 9600 x 9600 DPI, and fast scanning speeds, ensuring efficient digitization of documents.
- Canon i-SENSYS MF543x - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Max Copying Speed
- Up to 43 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 43 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
- Standard Media Capacity
- 650 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to SMB, scan to PC, iFAX
- Power
- AC 230 V (50/60Hz)
- 49.4 cm x 46.4 cm x 45.2 cm
- 19.8 kg
- 2-year Limited Warranty
- Printer Fonts
- PCL x 93 , PostScript x 136
- Fax Type
- Plain paper
- Laser - monochrome
- 150000 pages
- 2000 - 7500 pages
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Up to 43 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Up to 43 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF, TIFF, UFRII, JPEG
- First Print Out Time B/W
- 5.7 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 512 pages
- PC Faxing
- Yes (send only)
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 281 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 310 stations
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, fax activity reports
Document & Media Handling
- Min Original Size
- 105 x 128 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 105 x 128 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 199 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 650 sheets
- 100 sheets
- 150 sheets
- DSDF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 550 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 43 ppm (A4) - B/W , Printing: up to 65.2 ppm (A5) - B/W , Printing: up to 36 ipm (A4) - B/W duplex , Copying: up to 43 ppm (A4) - B/W , Copying: up to 34.4 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ipm - colour duplex
- 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Secure Print, SSL, Apple Bonjour, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering, SNMP 3
- Operating System Support
- Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14, MS Windows Server 2019
- Software Included
- Drivers & Utilities, iW Management Console, uniFLOW online, uniFLOW online Express
- Voltage Required
- 1430 Watt
- Power Consumption Standby
- 13.6 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 14 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 5100 pages - Canon 056L
- 49.4 cm
- 46.4 cm
- 45.2 cm
- 19.8 kg
- Sound Emission
- 24 dB (idle) / 54 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
