Save space with a compact design boasting print, scan and copy functionality, a perfect fit for productive businesses in need of a high-performance black and white laser printer.
Canon i-SENSYS MF542x in More Detail
The Canon i-SENSYS MF542x is a fast and versatile A4 mono multifunction printer that’s ideal for busy small businesses who need a reliable laser printer to meet the demands of their heavy workloads. Boasting ultra-fast print speeds and a range of versatile connectivity options, it’s ready to take your team’s productivity to the next level.
Ultra-fast printing
The Canon i-SENSYS MF542x is capable of printing at speeds of up to 43ppm in A4 and comes with a large capacity 550 sheet paper tray, making it ideal for larger print runs. Meanwhile, automatic double-sided printing and single-pass double-sided scanning make printing more efficient than ever, helping you get through your workload in less time.
Customisable controls
The Application Library allows you to tailor the on-screen controls and provides one-touch access to frequently used functions, like printing a saved form or scanning to email. What’s more, the Universal Login Manager (ULM) offers a variety of personalisation options and provides control over user printing rights.
Versatile mobile connectivity
The Canon i-SENSYS MF542x is truly designed for modern working schedules and offers a range of versatile connectivity options that make it easy to print from any device. There’s USB, Network, Wireless and Wi-Fi Direct connectivity, with full support for AirPrint (iOS) and Mopria (Android).
Advanced security
The secure PIN document release function provides control over confidential documents, while the Universal Login Manager (ULM) offers further privacy controls via user authentication.
High-quality printing at an affordable price
Whether you’re printing copies of an internal document or a long sales presentation, you can count on high-quality results at an affordable price. Genuine Canon toner cartridges such as the 056H High Capacity Black Toner Cartridge can even produce up to 21,000 pages* before needing a replacement.
Compact design
The i-SENSYS MF542x wraps high performance and advanced functionality into a sleek, compact body – perfect for those who are short on space.
Efficient connectivity
With options like Gigabit Ethernet, USB 2.0, and Wi-Fi(n), alongside mobile printing capabilities including Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any work environment. -
Advanced security
Equipped with comprehensive security protocols such as 802.1x, AES, and SSL, along with Secure Print and both IP and MAC address filtering, the Canon i-SENSYS MF542x offers peace of mind with enhanced data protection. -
High-quality copying
Features like automatic duplexing, a variety of copying features including 2 on 1, 4 on 1, and ID Card Copy, coupled with a maximum copying resolution of 600 x 600 DPI, ensure high-quality outputs for all copying needs. -
Intuitive display
A 12.7 cm color touchscreen display enhances user interaction, offering an intuitive interface for easy access to all printer functions. -
Robust document handling
With a DSDF document feeder, support for a wide range of media sizes and types, and a standard media capacity of 650 sheets, this printer is designed to handle large volumes efficiently.
- Canon i-SENSYS MF542x - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Max Copying Speed
- Up to 43 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 43 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
- Standard Media Capacity
- 650 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to SMB, scan to PC
- Power
- AC 230 V (50/60Hz)
- 48 cm x 46.4 cm x 45.2 cm
- 19.8 kg
- 2-year Limited Warranty
- Printer Fonts
- PCL x 93 , PostScript x 136
- Laser - monochrome
- 150000 pages
- 2000 - 7500 pages
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Up to 43 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Up to 43 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF, TIFF, UFRII, JPEG
- First Print Out Time B/W
- 5.7 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Min Original Size
- 105 x 128 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 105 x 128 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 199 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 650 sheets
- 100 sheets
- 150 sheets
- DSDF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 550 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 43 ppm (A4) - B/W , Printing: up to 65.2 ppm (A5) - B/W , Printing: up to 36 ipm (A4) - B/W duplex , Copying: up to 43 ppm (A4) - B/W , Copying: up to 34.4 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ipm - colour duplex
- 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Secure Print, SSL, Apple Bonjour, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering, SNMP 3
- Operating System Support
- Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14, MS Windows Server 2019
- Software Included
- Drivers & Utilities, iW Management Console, uniFLOW online, uniFLOW online Express
- Voltage Required
- 1430 Watt
- Power Consumption Standby
- 13.6 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 14 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 5100 pages - Canon 056L
- 48 cm
- 46.4 cm
- 45.2 cm
- 19.8 kg
- Sound Emission
- 24 dB (idle) / 54 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
