Canon i-SENSYS MF463dw Multifunction Printer
Quicklinx: HYZBWS00 Mfr#: 5951C026
10 In Stock
£280.12 ex VAT
£336.14 inc VAT
Enjoy robust security and high-speed, high-quality printing and scanning with multi-functional black and white laser printers in the i-SENSYS MF460 series.
  • Streamline workflows and accelerate efficiency
    Empower your workforce to save valuable time and boost productivity with the i-SENSYS MF460 series. Experience speedy printing and scanning and easily protect your devices from hacking and virus threats.
  • Protect documents
    360-degree security ensures complete document, device and network security. Security features include TLS 1.3, verify system at startup and secure PIN printing.
  • Intuitive user experience
    Easily carry out print and scanning jobs with one-touch buttons. Drag and drop icons help customize the display screen and allow you to perform routine tasks smoothly.
  • Boost productivity
    Save valuable time with print speeds of up to 40 ppm, scanning speeds of up to 100 ipm and a warm-up time of 14 seconds. Manage your printer using Universal Print from Microsoft.
  • Collaborate in the cloud
    Harness the power of the cloud with built-in connectivity to cloud storage services including Google Drive, DropBox, and OneDrive.
  • Save space
    A compact design helps you easily place devices on desktops or counters, maximizing office space as a result.
  • Mobile printing
    Conveniently print documents from your smartphone or tablet with the Canon PRINT Business app, or via AirPrint (iOS) and Mopria (Android).
Canon i-SENSYS MF463dw - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Display
5"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
Standard Media Capacity
350 sheets
Max Media Capacity
900 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, Push Scan, Pull Scan, scan to PC, print from cloud, Secure Print, scan to USB drive
AC 230 V (50/60Hz)
42 cm x 46 cm x 37.5 cm
16.3 kg
Environmental Standards
ENERGY STAR Qualified
Printer Fonts
PCL x 45 , PostScript 3 x 136
Printing Technology
Laser - monochrome
80000 pages
750 - 4000 pages
Display Diagonal Size
5"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Flash Memory
Flash Memory
4 GB
Copying
Max Copying Speed
Up to 40 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, collation copy, passport copy
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm), Foolscap (216 x 343 mm), A5 Landscape
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
199 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 216 x 355.6 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm), 105 x 128 mm, 216 x 341 mm, A5 Landscape
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
350 sheets
Max Media Capacity
900 sheets
100 sheets
150 sheets
Paper cassette - 250 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Multi-purpose tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m² , ADF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 33.6 ipm (A4) - B/W duplex , Printing: up to 65.4 ppm (A5) - B/W , Scanning: up to 50 ipm - B/W (300 dpi) , Scanning: up to 40 ipm - colour (300 dpi) , Scanning: up to 100 ipm - B/W duplex (300 dpi) , Scanning: up to 80 ipm - colour duplex (300 dpi) , Scanning: up to 40 ipm - B/W (600 x 300 dpi) , Scanning: up to 20 ipm - colour (600 x 300 dpi) , Scanning: up to 80 ipm - B/W duplex (600 x 300 dpi) , Scanning: up to 40 ipm - colour duplex (600 x 300 dpi) , Copying: up to 40 ppm - B/W , Copying: up to 33.6 ipm - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Secure Print, SSL, WEP, WPA-PSK, IPsec, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, Wi-Fi Direct, IPv6 support, SNMP 3, WPA2-EAP, TLS 1.3 Encryption, IPv4 support, SMTP, POP3, WPA-EAP, SNMP 1, SMB v3
Operating System Support
Linux, MS Windows Server 2012, MS Windows Server 2012 R2, Windows 10, MS Windows Server 2016, macOS 10.13 or later, MS Windows Server 2019, Windows 11, MS Windows Server 2022
Software Included
Drivers & Utilities, Canon Print Service Plug-in for Android, Canon PRINT Business, iW Enterprise Management Console, eMaintenance, Toner Status, MF Scan Utility
AC 230 V (50/60Hz)
480 Watt
Power Consumption Standby
8 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
14 sec
First Copy Out Time B/W
6.1 sec
Consumables Included
1 x toner cartridge (black) - up to 3000 pages - Canon 070
ISO 7779, ISO/IEC 19752, ISO 9296
ENERGY STAR Certified
42 cm
46 cm
37.5 cm
16.3 kg
Sound Emission
53 dB (operating)
10 °C
30 °C
20 - 80% RH (non-condensing)
HYZB Canon Canon 070H - High capacity - black - original - toner In Stock £165.24
Brand: Canon
