Canon I-SENSYS MF4570DN 25PPM MONO
Quicklinx: 7HNZWS00 Mfr#: 4509B099AA
This compact, network-ready 4-in-1 is designed for small teams in the office or for personal use at home. Productive and stylish it offers high quality print, copy, scan and fax functionality in one space saving device.
An enhanced print resolution of up to 1200 x 600 dpi delivers professional laser output for all your work, with sharp text and fine graphics. Impress customers, colleagues and friends by printing professional looking double-sided documents - whilst saving paper at the same time.
The i-SENSYS 4570dn is network-ready, enabling small teams to easily share its productive capabilities. As well as offering network scanning, a Remote User Interface lets users and administrators monitor and manage machine status directly from their web browsers.
The i-SENSYS MF4570dn features a simple and intuitive LCD interface designed for easy operation. With 5 lines of text plus animations, features can be quickly and easily accessed and more information can be communicated saving time and effort.
With an output speed of 25 ppm and a fast first copy out time of less than 9 seconds, prints and copies are delivered the moment you need them. With quick recovery from sleep mode, thanks to Quick First-Print technologies, long waits for your documents are a thing of the past. Additionally, this economical device uses only 3 watts in sleep mode, ensuring energy efficiency.
  • Compact and stylish
  • Superior image quality
  • Network ready
  • Easy to use
  • Save time and energy
  • Versatile color scanning
    Scanning color documents and photos is easy and highly versatile using a resolution as high as 9600 x 9600 dpi. Files can be scanned directly to email, or searchable PDF using the MF Toolbox, enabling them to be quickly retrieved in the future.
Canon i-SENSYS MF4570dn - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
10000 impressions
Max Copying Speed
Up to 25 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Max Printing Resolution
Up to 1200 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
Scanning
600 x 600 dpi
Answering Machine
(up to 5 min)
Original Size
105 x 148 mm (min) - 216 x 356 mm (max)
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - 216 x 356 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, heavy-weight paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN
AC 230 V (50/60Hz)
39 cm x 42.1 cm x 37 cm
12.3 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 impressions
Display
5 lines
USB 2.0, LAN
Standard Memory
64 MB 64 MB
Copying
Max Copying Speed
Up to 25 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Up to 25 ppm
Printer Drivers / Emulations
UFRII LT
Image Enhancement Technology
Automatic Image Refinement
Automatic Duplexing
First Print Out Time B/W
6 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 256 pages
PC Faxing
Yes (send only)
Fax Machine Features
One-Touch Dialing
4 station(s)
Speed Dialing
104 station(s)
Telephone / Fax Switch
Broadcast Transmission
50 stations
Delayed Transmission
114 stations
Remote reception, Dual Access
Answering Machine
Recording Capacity
Up to 5 min
Document & Media Handling
Min Original Size
105 x 148 mm
Max Original Size
216 x 356 mm
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
250 sheets
100 sheets
Paper cassette - 250 sheets size: 76 x 210 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets , ADF - 35 sheets size: 105 x 148 mm - 216 x 356 mm
Speed Details
Copying: up to 25 ppm (A4) - B/W , Printing: up to 25 ppm (A4) - B/W
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.4.9 - 10.6.x
Software Included
Drivers & Utilities, Presto! PageManager
AC 230 V (50/60Hz)
1220 Watt
Power Consumption Sleep
3 Watt
Warm-Up Time
12 sec
First Copy Out Time B/W
9 sec
Consumables Included
1 x toner cartridge (black) - up to 2100 pages - Canon 728
ENERGY STAR Certified
39 cm
42.1 cm
37 cm
12.3 kg
Sound Emission
43 dB (operating)
10 °C
30 °C
20 - 80%
