Canon i-SENSYS MF449x Mono Laser Multifunction Printer
Quicklinx: FRZGWS00 Mfr#: 3514C032
The MF449x has it all - print, scan, copy and fax from one sleek machine and keep a tight rein on security and costs via the Universal Login Manager (ULM). Customizable controls make operation even more user-friendly.
A smart, connected B&W printer to give your business the professional edge
Get the most from your small office with this compact, multi-talented MF449x. Easy to control from a touch screen display, this smart printer can be networked, enabling your entire team to print, copy, scan and fax from any device. Plus, with cost and waste saving features you’ll protect the environment and your budget.
Take control of your print environment
Always be in control with an intuitive 5 inch Touch LCD Display loaded with details you need to operate, manage and maintain your printer.
Never miss a beat, even when you’re out and about
Don’t lose time. Print on the go from your smartphone or tablet using AirPrint, Mopria for Andriod and Canon’s Print Business app.
Built for connectivity
Boost productivity with your networked office integrating PCL5e/6 and Adobe PostScript printer languages thanks to WiFi and Ethernet connectivity.
Equipped for smart printing on the fly
Don’t hold back. With Google Cloud Print, Apple® AirPrint, Mopria (Android) and Canon’s PRINT Business app, you can print from any smart device.
Connected so you can share and collaborate
Connect, share and collaborate for best results with MF Scan Utility, Canon’s PRINT Business app and cloud storage like Evernote® and DropBox.
Compact yet impressive
Achieve professional results in black and white at high speeds from your robust compact printer that can fit into the smallest, busiest workspace.
Speedy from the get go
No waiting required. Your MF449X prints within 6 seconds then races at up to 38ppm at an impressive 600 x 600 dpi with capacity for 1200 x 600 dpi.
Protect your environment and your budget
Protect your environment with low energy consumption, a smart power-saving Auto Off feature and automatic duplex printing to reduce paper waste.
  • Efficient connectivity
    With a range of connectivity options including USB 2.0, Wi-Fi(n), and support for various mobile printing capabilities like Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any workflow.
  • Advanced security
    Equipped with robust security protocols including AES, Secure Print, and Wi-Fi Direct, the Canon i-SENSYS MF449x offers peace of mind with secure document handling and communication.
  • High-quality copying
    Automatic duplexing, multiple copying features, and a maximum copying resolution of 600 x 600 DPI enable the production of high-quality documents efficiently.
  • Versatile media handling
    Supports a wide range of media sizes and types, including envelopes, labels, and postcards, making it ideal for diverse printing needs.
  • Fast and reliable performance
    With a first print out time of just 5.5 seconds and a maximum printing speed of 38 ppm, this printer is designed to meet high productivity demands.
Canon i-SENSYS MF449x - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 38 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 38 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
Standard Media Capacity
350 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to SMB, scan to PC, iFAX
AC 230 V (50/60Hz)
45.3 cm x 46.4 cm x 39.2 cm
17.2 kg
2-year Limited Warranty
Printer Fonts
PCL x 93 , PostScript 3 x 136
Fax Type
Plain paper
Printing Technology
Laser - monochrome
80000 pages
750 - 4000 pages
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Up to 38 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Up to 38 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, TIFF, UFRII, JPEG, PNG
Automatic Duplexing
First Print Out Time B/W
5.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 512 pages
PC Faxing
Yes (send only)
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
281 station(s)
Telephone / Fax Switch
Broadcast Transmission
310 stations
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, group dialling, remote reception, Dual Access, fax activity reports
Document & Media Handling
Min Original Size
105 x 128 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 105 x 128 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
350 sheets
100 sheets
150 sheets
DSDF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 38 ppm (A4) - B/W , Printing: up to 63.1 ppm (A5) - B/W , Printing: up to 30.3 ipm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - B/W , Copying: up to 30.3 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ppm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering, Wi-Fi Direct, SNMP 3
Operating System Support
Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14, MS Windows Server 2019
Software Included
iW Management Console, uniFLOW online, uniFLOW online Express, Universal Login Manager
AC 230 V (50/60Hz)
1370 Watt
Power Consumption Standby
9.4 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
14 sec
Consumables Included
1 x Cartridge (black) - up to 3100 pages ISO/IEC 19752 - Canon 057
45.3 cm
46.4 cm
39.2 cm
17.2 kg
Sound Emission
53 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
2-year Manufacturer Warranty
FRZG Canon i-SENSYS 057 Toner Cartridge Black In Stock £83.54
FRZG Canon 3010C002 057H Black Toner Cartridge 10K Page In Stock £146.48
