Canon i-SENSYS MF446x Mono Laser Multifunction Printer
Quicklinx: FRZFWS00 Mfr#: 3514C043
Highly productive and efficient, the MF446x also benefits from customizable controls, wireless connectivity and the extensive security and cost-saving measures of the Universal Login Manager (ULM).
This fast and efficient mono laser printer from Canon has been optimised for small to medium-sized businesses with a multifunctional design that allows you to print, copy and scan from one machine. Offering a compact and space-saving solution, it includes intelligent mobile connectivity and an application library for customisable control. For added security, it includes Secure PIN release and Universal Login Manager controls and has a user-friendly 12.7cm colour touchscreen.
  • Efficient connectivity
    With a range of connectivity options including Gigabit Ethernet, USB 2.0, and Wi-Fi(n), alongside mobile printing capabilities through Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any workflow.
  • Advanced security
    Equipped with comprehensive security protocols such as 802.1x, AES, and Secure Print, the Canon i-SENSYS MF446x safeguards sensitive information, making it a suitable choice for businesses concerned with document confidentiality.
  • High-quality copying
    Automatic duplexing, a variety of copying features like 2 on 1, 4 on 1, and ID Card Copy, combined with a maximum copying resolution of 600 x 600 DPI, ensure high-quality outputs for all copying needs.
  • Intuitive display
    A 12.7 cm color touchscreen display enhances user experience by providing easy navigation and quick access to all printer functions.
  • Versatile media handling
    Supports a wide range of media sizes and types, including envelopes, heavy-weight paper, and labels, with a maximum media size of up to Legal (216 x 356 mm), catering to diverse printing needs.
Canon i-SENSYS MF446x - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 38 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 38 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Original Size
105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
Standard Media Capacity
350 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to SMB, scan to PC
AC 230 V (50/60Hz)
45.3 cm x 46.4 cm x 39.2 cm
17.2 kg
2-year Limited Warranty
Printer Fonts
PCL x 93 , PostScript 3 x 136
Printing Technology
Laser - monochrome
80000 pages
750 - 4000 pages
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Up to 38 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Up to 38 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
5.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Min Original Size
105 x 128 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 105 x 128 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
350 sheets
100 sheets
150 sheets
DSDF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 38 ppm (A4) - B/W , Printing: up to 63.1 ppm (A5) - B/W , Printing: up to 30.3 ipm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - B/W , Copying: up to 30.3 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ppm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering, Wi-Fi Direct, SNMP 3
Operating System Support
Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14, MS Windows Server 2019
Software Included
iW Management Console, uniFLOW online, uniFLOW online Express, Universal Login Manager
AC 230 V (50/60Hz)
1370 Watt
Power Consumption Standby
9.4 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
14 sec
Consumables Included
1 x Cartridge (black) - up to 3100 pages ISO/IEC 19752 - Canon 057
45.3 cm
46.4 cm
39.2 cm
17.2 kg
Sound Emission
53 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
FRZF Canon i-SENSYS 057 Toner Cartridge Black In Stock £83.76
FRZF Canon 3010C002 057H Black Toner Cartridge 10K Page In Stock £152.00
