Canon i-SENSYS MF445dw Mono Laser Multifunction Printer
Quicklinx: FRZDWS00 Mfr#: 3514C020
Print, scan, copy and fax from this compact model, which also benefits from customisable controls, single-pass double-sided scanning and versatile mobile printing options.
Keep your business running smoothly with a robust black and white laser with print, scan, copy and fax functionality. Push productivity with rapid A4 print speeds of up to 38 ppm, double-sided single-pass scanning and double-sided printing, and get your workforce up to speed with customised controls. Tailor the printer to fit your business' needs with the Application Library and automate daily tasks or personalise on-panel functions. Control couldn't be simpler using the 12.7 cm colour touchscreen or via a smart device – seamless wireless connectivity means you can print, scan, copy and connect to the cloud via the Canon PRINT app or print straight away with AirPrint (iOS) and Mopria (Android). For security, take advantage of Secure PIN Printing.
  • Efficient connectivity
    With a wide range of connectivity options including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi, alongside mobile printing capabilities like Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any work environment.
  • Advanced security
    Equipped with robust security protocols such as 802.1x, AES, ARP, IP filtering, MAC address filtering, SNMP 3, SSL, Secure Print, and more, the Canon i-SENSYS MF445dw safeguards sensitive information, making it ideal for confidential document handling.
  • High-quality copying and printing
    Boasts automatic duplexing for efficient two-sided printing and copying, with a maximum copying resolution of 600 x 600 DPI and a printing resolution of 1200 x 1200 DPI, ensuring crisp, clear documents. The first print out time of just 5.5 sec and speeds up to 38 ppm streamline workflow and increase productivity.
  • Versatile media handling
    Supports a broad range of media sizes and types, including envelopes, labels, plain paper, postcards, and recycled paper, accommodating diverse printing needs. The device's flexible media handling capabilities are further enhanced by a bypass feeder capacity of 100 sheets, a standard media capacity of 350 sheets, and automatic document feeder.
  • Comprehensive scanning features
    Features automatic duplex scanning with a color depth of 24-bit and an optical resolution of 600 x 600 DPI, enabling high-quality scans. Speed details reveal impressive rates, including up to 38 ipm for black and white and 13 ipm for color, facilitating efficient digitization of documents.
Canon i-SENSYS MF445dw - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 38 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 38 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
Standard Media Capacity
350 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud, iFAX
AC 230 V (50/60Hz)
45.3 cm x 46.4 cm x 39.2 cm
17.2 kg
2-year Limited Warranty
Printer Fonts
PCL x 45 , PostScript 3 x 136
Fax Type
Plain paper
Printing Technology
Laser - monochrome
80000 pages
750 - 4000 pages
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Up to 38 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Up to 38 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
5.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 512 pages
PC Faxing
Yes (send only)
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
281 station(s)
Telephone / Fax Switch
Broadcast Transmission
310 stations
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, group dialling, remote reception, Dual Access, Double Sided Faxing, fax memory backup, fax activity reports
Document & Media Handling
Min Original Size
105 x 128 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 105 x 128 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
350 sheets
100 sheets
150 sheets
DSDF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 38 ppm (A4) - B/W , Printing: up to 63.1 ppm (A5) - B/W , Printing: up to 31.9 ipm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - B/W , Copying: up to 30.3 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering, SNMP 3
Operating System Support
Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14, MS Windows Server 2019
Software Included
Drivers & Utilities, iW Management Console
AC 230 V (50/60Hz)
1370 Watt
Power Consumption Standby
9.4 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
14 sec
Consumables Included
1 x Cartridge (black) - up to 3100 pages - Canon 057
45.3 cm
46.4 cm
39.2 cm
17.2 kg
Sound Emission
53 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
FRZD Canon i-SENSYS 057 Toner Cartridge Black In Stock £82.46
