A multifunctional black and white printer optimized for small and medium-sized businesses. Durable, reliable and fast, the MF443dw also features customizable controls and mobile connectivity.
Keep your business running smoothly with a robust 3-in-1 mono laser printer. Push productivity with rapid A4 print speeds of up to 38 ppm, double-sided single-pass scanning and double-sided printing, and get your workforce up to speed with simplified and customised controls. Tailor the printer to fit your business' needs with the Application Library and automate daily tasks or personalise on-panel functions. Control couldn't be simpler using the 12.7 cm colour touchscreen or via a smart device – seamless wireless connectivity means you can print, scan, copy and connect to the cloud via the Canon PRINT app or print straight away with AirPrint (iOS) and Mopria (Android). For security, take advantage of Secure PIN Printing.
Efficient connectivity
With a range of connectivity options including Gigabit Ethernet, USB 2.0, Wi-Fi(n), and mobile printing capabilities like Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any work environment. -
Advanced security
Equipped with robust security protocols such as 802.1x, AES, and Secure Print, alongside features like IP and MAC address filtering, this printer offers peace of mind by keeping your documents safe. -
High-quality printing
Achieve professional-quality prints with a maximum resolution of 1200 x 1200 DPI and automatic duplexing, ensuring your documents look sharp while saving on paper. -
Versatile media handling
From envelopes to heavy-weight paper and postcards, this printer accommodates a wide range of media sizes and types, making it ideal for various printing needs. -
Fast and efficient operation
With a first print out time of just 5.5 seconds and speeds up to 38 ppm, along with a recommended monthly volume of 750 - 4000 pages, this device is built to keep up with the demands of busy workgroups.
- Canon i-SENSYS MF443dw - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Speed
- Up to 38 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 38 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
- Standard Media Capacity
- 350 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to SMB, scan to PC
- Power
- AC 230 V (50/60Hz)
- 45.3 cm x 46.4 cm x 39.2 cm
- 17.2 kg
- 2-year Limited Warranty
- Printer Fonts
- PCL x 45
- Laser - monochrome
- 80000 pages
- 750 - 4000 pages
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Up to 38 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Up to 38 ppm
- Printer Drivers / Emulations
- PCL 6, PCL 5c, PDF, TIFF, UFRII, JPEG
- First Print Out Time B/W
- 5.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Min Original Size
- 105 x 128 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 105 x 128 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 350 sheets
- 100 sheets
- 150 sheets
- DSDF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 38 ppm (A4) - B/W , Printing: up to 63.1 ppm (A5) - B/W , Printing: up to 30.3 ipm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - B/W , Copying: up to 30.3 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ipm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
- Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering, Wi-Fi Direct, SNMP 3
- Operating System Support
- Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14, MS Windows Server 2019
- Software Included
- iW Management Console
- Voltage Required
- 1370 Watt
- Power Consumption Standby
- 9.4 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 14 sec
- Consumables Included
- 1 x Cartridge (black) - up to 3100 pages ISO/IEC 19752 - Canon 057
- 45.3 cm
- 46.4 cm
- 39.2 cm
- 17.2 kg
- Sound Emission
- 53 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
Canon i-SENSYS 057 Toner Cartridge Black | In Stock | £77.78 |
Canon 3010C002 057H Black Toner Cartridge 10K Page | In Stock | £146.67 |
