The i-SENSYS MF420 series are multi-function printers offering SMEs speed, durability, and quality. Mobile connectivity maximises productivity.
- Save time with fast print speeds of up to 38ppm
- Increase productivity with double sided single pass scanning
- High quality 1200 x 1200 dpi print resolution
- Easy operation with large colour touch screen
- Improved flexibility with varied media support; A4, A5,A6
- Increase control with the Universal Login Manager (MF428x and MF429x)
- Enhanced security & accounting with uniFLOW (MF428x and MF429x)
- Improve quality & reliability with Canon Genuine all-in-one cartridges
- Application Library allowing automation, added shortcuts and a customised interface
- Secure PIN feature allowing employers and employees maximum control over print jobs
Efficient connectivity
With options like Gigabit Ethernet, USB 2.0, and Wi-Fi(n), alongside AirPrint compatibility, this device ensures seamless integration into any work environment, facilitating easy sharing and management of documents. -
Advanced security
Equipped with comprehensive security protocols including 802.1x, ARP, IP filtering, and more, the Canon i-SENSYS MF428x safeguards sensitive information, ensuring that document confidentiality is maintained. -
High-quality copying
Automatic duplexing, multiple copying features, and a maximum copying resolution of 600 x 600 DPI combine to deliver high-quality copies swiftly, enhancing productivity. -
Versatile media handling
Supports a wide range of media sizes and types, from envelopes to heavy-duty paper, making it ideal for diverse printing needs. The inclusion of a DSDF document feeder optimizes the scanning and copying of multi-page documents. -
Robust printing and scanning
Achieves a maximum printing speed of 38 ppm with a high resolution of 1200 x 1200 DPI, alongside comprehensive scanning functionality that includes color depth of 24-bit and an interpolated resolution of 9600 x 9600 DPI, ensuring crisp, clear document output.
- Canon i-SENSYS MF428x - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Speed
- Up to 38 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 38 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
- Standard Media Capacity
- 350 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, Google Cloud Print ready, Mopria certified, scan to SMB, iFAX
- Power
- AC 230 V (50/60Hz)
- 45.3 cm x 46.4 cm x 39.2 cm
- 16.9 kg
- Printer Fonts
- PCL x 93 , PostScript x 136
- Laser - monochrome
- 80000 pages
- 750 - 4000 pages
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Up to 38 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Up to 38 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF, TIFF, UFRII, JPEG
- First Print Out Time B/W
- 5.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Min Original Size
- 105 x 128 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm)
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 350 sheets
- 100 sheets
- 150 sheets
- ADF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 38 ppm (A4) - B/W , Printing: up to 63.1 ppm (A5) - B/W , Printing: up to 30.3 ipm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - B/W , Copying: up to 30.3 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ppm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering
- Operating System Support
- Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.8.5 or later, MS Windows Server 2016
- Software Included
- Drivers & Utilities, iW Management Console, uniFLOW online, uniFLOW online Express, Universal Login Manager
- Voltage Required
- 1300 Watt
- Power Consumption Standby
- 10 Watt
- Power Consumption Sleep
- 0.9 Watt
- First Copy Out Time B/W
- 6.6 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3100 pages - Canon 052
- 45.3 cm
- 46.4 cm
- 39.2 cm
- 16.9 kg
- Sound Emission
- 55 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
