Make quick prints, copies and scans at your convenience, straight from your desktop with this compact mono laser printer. Ideal for home and small offices it's easy to use and energy efficient.
The sleek and stylish, all black design of the MF3010 makes it a very smart multifunctional laser 3-in-1. There's a high-quality mono printer, scanner and copier in one space-saving unit. Fast and economic to run, this eye-catching compact device fits easily on the desktop. It is perfect for personal or small and home office users who want more than just a printer and are looking to save time and money.
You can operate the MF3010 from the comfort of your chair, thanks to the simple, vertical display. This gives you convenient access to all the features you need without having to stand over the machine, saving you time and effort.
Ultra-compact, modern design
The sleek and stylish, all black design of the MF3010 makes it a very smart multifunctional laser 3-in-1. There's a high-quality mono printer, scanner and copier in one space-saving unit. Fast and economic to run, this eye-catching compact device fits easily on the desktop. It is perfect for personal or small and home office users who want more than just a printer and are looking to save time and money. -
Easy to use
You can operate the MF3010 from the comfort of your chair, thanks to the simple, vertical display. This gives you convenient access to all the features you need without having to stand over the machine, saving you time and effort. -
Quality and speed
Be sure of highly professional laser prints with up to 1200 x 600 dpi enhanced print resolution. This shows greater detail and produces sharp text and fine graphics. There's little waiting time for documents, with a mono printing output speed of 18 ppm. Canon's quick first-print technologies also means a fast first print out time of 7.8 seconds. -
Versatile color scanning and copying
Increase your efficiency with the high quality color scanner. It makes it easy to scan and copy your documents - instantly improving your productivity. There's no hanging around with a first copy out time of less than 12 seconds. You can also scan direct to email, or searchable PDF using the MF Toolbox, for quick retrieval of your documents and photos. -
Save energy and cut costs
Truly economical, the MF3010 leads the way in energy efficiency, without compromising on performance - allowing you to save money as well as reduce your carbon footprint. The multifunctional device is ENERGY STAR compliant with a Typical Energy Consumption (TEC) of 0.6 kWh. In sleep mode it only consumes 1.4 watts of energy.
- Canon i-SENSYS MF3010
- Printing Technology
- Laser
- Original Type
- Sheets
- Media Type
- Plain paper
- Connection Availability
- Laser
Copying
- Grayscale Half-Tones
- 256
- Exposure Modes
- Text, text and photo
Scanning
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Plain paper
- 30 °C
- 2 Years
Canon 725 BLACK TONER | In Stock | £50.72 |
