Canon I-SENSYS MF3010 Laser Multifuction
Quicklinx: GV4PWS00 Mfr#: 5252B035
Type: Printer / copier / scanner
Functionality: Printer, Scanner, Copier
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
£183.72 ex VAT
£220.46 inc VAT
Make quick prints, copies and scans at your convenience, straight from your desktop with this compact mono laser printer. Ideal for home and small offices it's easy to use and energy efficient.
The sleek and stylish, all black design of the MF3010 makes it a very smart multifunctional laser 3-in-1. There's a high-quality mono printer, scanner and copier in one space-saving unit. Fast and economic to run, this eye-catching compact device fits easily on the desktop. It is perfect for personal or small and home office users who want more than just a printer and are looking to save time and money.
You can operate the MF3010 from the comfort of your chair, thanks to the simple, vertical display. This gives you convenient access to all the features you need without having to stand over the machine, saving you time and effort.
  • Ultra-compact, modern design
  • Easy to use
  • Quality and speed
    Be sure of highly professional laser prints with up to 1200 x 600 dpi enhanced print resolution. This shows greater detail and produces sharp text and fine graphics. There's little waiting time for documents, with a mono printing output speed of 18 ppm. Canon's quick first-print technologies also means a fast first print out time of 7.8 seconds.
  • Versatile color scanning and copying
    Increase your efficiency with the high quality color scanner. It makes it easy to scan and copy your documents - instantly improving your productivity. There's no hanging around with a first copy out time of less than 12 seconds. You can also scan direct to email, or searchable PDF using the MF Toolbox, for quick retrieval of your documents and photos.
  • Save energy and cut costs
    Truly economical, the MF3010 leads the way in energy efficiency, without compromising on performance - allowing you to save money as well as reduce your carbon footprint. The multifunctional device is ENERGY STAR compliant with a Typical Energy Consumption (TEC) of 0.6 kWh. In sleep mode it only consumes 1.4 watts of energy.
Canon i-SENSYS MF3010
Printing Technology
Laser
Original Type
Sheets
Media Type
Plain paper
Connection Availability
Printing Technology
Laser
Copying
Grayscale Half-Tones
256
Exposure Modes
Text, text and photo
Scanning
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Original Type
Sheets
Max Media Size
A4/Legal
Supported Media Type
Plain paper
30 °C
2 Years
GV4P Canon 725 BLACK TONER In Stock £50.37
Functionality: Scanner
Functionality: Copier
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
