Streamline printing processes and enhance efficiency at home or in small offices with speedy and reliable mono multifunction laser printers.
Empower your workforce
Discover the power of small devices, with the fast and reliable i-SENSYS MF270 Series. Print speeds of 29ppm and double-sided printing contribute towards a seamless workflow, allowing you to work smarter, not harder. -
Boost productivity
Maximize output by printing, copying and scanning documents from reliable devices. Fax with the MF275dw, save time with duplex printing and use a wide variety of small media support to produce A5 and A6R sized documents. -
Protect sensitive documents
Protect your documents, devices and network from viruses and data theft with 360-degree security. Features include secure start up and a security navigation guide. -
Ease of use
Save time with an easy out-of-box experience and seamlessly navigate settings using an intuitive display panel. Simple Wi-Fi connectivity and mobile printing allows you to print from your smart phones.
- Canon i-SENSYS MF272dw - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 150 - 2000 pages
- Max Copying Speed
- Up to 29 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 29 ppm
- Max Printing Resolution
- Up to 2400 x 600 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 76 x 127 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, thin paper, postcards
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to PC, scan to Cloud, access point mode
- Power
- AC 220-240 V (50/60Hz)
- 37.2 cm x 32 cm x 27.1 cm
- 9 kg
- 1-year warranty
- Laser - monochrome
- 20000 pages
- 150 - 2000 pages
- Display
- 5 lines
- Display Colour Support
- Monochrome
- Display Features
- LCD display
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
Copying
- Max Copying Speed
- Up to 29 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, collation copy, passport copy
Printing
- Up to 29 ppm
- Printer Drivers / Emulations
- UFRII, JPEG, TIFF, PDF, PNG
- First Print Out Time B/W
- 5.4 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Min Original Size
- 76 x 127 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), B5 (176 x 250 mm), Legal (216 x 356 mm), ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), Statement (139.7 x 215.9 mm), Foolscap (216 x 343 mm), Oficio (216 x 343 mm), 76.2 x 127 mm, B6 (125 x 176 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 1 sheet
- 50 sheets
- Paper cassette - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Multi-purpose tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 50 sheets
- Speed Details
- Printing: up to 29 ppm (A4) - B/W , Printing: up to 18.5 ppm (A4) - B/W duplex , Copying: up to 29 ppm (A4) - B/W , Copying: up to 18.5 ppm (A4) - B/W duplex , Scanning: 2.7 sec - B/W , Scanning: 3.5 sec - colour
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
- WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering, TLS 1.3 Encryption, SNMP 3, SSL, IPv4 support, IPv6 support
- Operating System Support
- Linux, MS Windows Server 2012, Windows 8.1, MS Windows Server 2012 R2, Windows 10, MS Windows Server 2016, MS Windows Server 2019, MS Windows Server 2022, Windows 11, macOS 10.12 or later
- Voltage Required
- 530 Watt
- Power Consumption Standby
- 4.8 Watt
- Power Consumption Sleep
- 1 Watt
- First Copy Out Time B/W
- 8.9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages - Canon 071 , 1 x toner cartridge (black) - up to 2500 pages - Canon 071H
- Limited warranty - 1 year
- 37.2 cm
- 32 cm
- 27.1 cm
- 9 kg
- Sound Emission
- 51 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% RH (non-condensing)
