Professional 3-in-1 mono laser printer perfect for small workgroups, with fast, high-quality, double-sided printing and enhanced mobile and cloud capabilities, plus network integration features.
Remote monitoring
Access printer information, change network settings, set up the address book and check toner levels - all from the remote user interface. -
Sustainable performance
The printer's eco reports make it easy to monitor and track usage, while auto off and reduced power consumption modes help keep your carbon footprint to a minimum.
- Canon i-SENSYS MF244dw - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 500 - 2500 pages
- Max Copying Speed
- Up to 27 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 27 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 105 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, heavy-weight paper, postcards
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to Cloud, scan to PC
- Power
- AC 230 V (50/60Hz)
- 39 cm x 37.1 cm x 36 cm
- 12.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - monochrome
- 15000 pages
- 500 - 2500 pages
- Display
- 5 lines
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
- Up to 27 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Memory Sort
Printing
- Up to 27 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, UFRII LT
- First Print Out Time B/W
- 6 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Min Original Size
- 105 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm), 76.2 x 210 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Paper cassette - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 35 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m²
- Speed Details
- Printing: up to 27 ppm (A4) - B/W , Printing: up to 15 ipm (A4) - B/W duplex , Copying: up to 27 ppm (A4) - B/W , Scanning: up to 20 ipm - B/W (300 dpi) , Scanning: up to 15 ipm - colour (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering
- Operating System Support
- Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, Apple Mac OS X 10.6 or later, MS Windows Server 2012 R2, Windows 10
- Software Included
- Drivers & Utilities, Presto! PageManager
- Voltage Required
- 1150 Watt
- Power Consumption Standby
- 4.1 Watt
- Power Consumption Sleep
- 1.3 Watt
- First Copy Out Time B/W
- 9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 900 pages
- ENERGY STAR Certified
- 39 cm
- 37.1 cm
- 36 cm
- 12.1 kg
- Sound Emission
- 52 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
