Canon I-SENSYS MF237W Laser Multifuction
Quicklinx: GV4NWS00 Mfr#: 1418C176AA
Enjoy this connected 4-in-1 mono laser printer, built to deliver everything, a small office needs: print, copy, scan and fax from PCs, smartphones and tablets.
An ideal office companion
If you run a small business or work from a home office, you’ll appreciate the fast, reliable mono print quality, touchscreen display and print, copy, scan and fax.
Monitor from a PC or mobile
Access printer information, change network settings, set up the address book and check toner levels – all from the Remote User Interface (RUI).
Sustainability matters
The printer’s ECO reports make it easy to monitor and track usage, while Auto Off and reduced power consumption modes help keep your carbon footprint to a minimum.
  • An ideal office companion
    If you run a small business or work from a home office, you'll appreciate the fast, reliable mono print quality, touchscreen display and print, copy, scan and fax.
  • Monitor from a PC or mobile
    Access printer information, change network settings, set up the address book and check toner levels - all from the remote user interface (RUI).
  • Sustainability matters
    The printer's eco reports make it easy to monitor and track usage, while auto off and reduced power consumption modes help keep your carbon footprint to a minimum.
Canon i-SENSYS MF237w - B/W
Printing Technology
Laser (monochrome)
Original Type
Sheets
Media Type
Envelopes, plain paper, labels
Automatic Duplexing
Yes (printing)
Connection Availability
AirPrint Enabled
AC 230 V
2 Years
Printing Technology
Laser - monochrome
AirPrint Enabled
Copying
Grayscale Half-Tones
256
Max Document Reduction
25%
Printing
Automatic Duplexing
Scanning
Colour Depth
24-bit
Document & Media Handling
Original Type
Sheets
Supported Media Type
AC 230 V
30 °C
2 Years
GV4N Canon CRG-737 Black Toner Cartridge In Stock £62.27
