Get beautiful streak-free mono prints with the all-in-one Cartridge 737 which works seamlessly with Canon i-SENSYS MF231, MF232w, MF237w, MF244dw, MF247dw and MF249dw to give you approximately 2,400 pages (ISO/IEC 19752 measured).
Efficient copying
With features like 2 on 1, 4 on 1, ID Card Copy, Memory Sort, and Toner Save, the Canon i-SENSYS MF231 streamlines your copying tasks, making it ideal for both office and home use. Maximize productivity with a first copy out time of just 9 seconds and a maximum copying resolution of 600 x 600 DPI. -
Versatile media handling
The Canon i-SENSYS MF231 supports a wide range of media sizes from 76.2 x 127 mm to Legal (216 x 356 mm) and types including envelopes, plain paper, labels, and heavy-weight paper, making it perfect for various printing needs. Its 250-sheet capacity and support for up to 163 g/m2 media weight allow for efficient, uninterrupted printing. -
High-quality printing
Achieve professional monochrome prints with a maximum printing resolution of 1200 x 1200 DPI and speeds up to 23 ppm. The first print out time of just 6 seconds means you won't be waiting around for your documents. -
Advanced scanning capabilities
With an optical resolution of 600 x 600 DPI and color depth of 24-bit, the Canon i-SENSYS MF231 delivers high-quality scans. Fast scanning speeds of up to 3 seconds for B/W and 4 seconds for color at 300 DPI ensure efficiency in digitizing your documents. -
Eco-friendly design
ENERGY STAR certified, the Canon i-SENSYS MF231 is designed with energy efficiency in mind. Operating at a maximum power consumption of 1120 watts and as low as 1.2 watts in sleep mode, it helps reduce your carbon footprint and energy costs.
- Canon i-SENSYS MF231 - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 500 - 2000 pages
- Max Copying Speed
- Up to 23 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 23 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 216 mm width (max)
- Original Type
- Sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, bond paper, heavy-weight paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0
- Office Machine Features
- Scan to PC
- Power
- AC 230 V (50/60Hz)
- 39 cm x 37.1 cm x 31.2 cm
- 10.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - monochrome
- 15000 pages
- 500 - 2000 pages
- Display
- 5 lines
- Interface
- USB 2.0
- Scan to PC
- Standard Memory
- 128 MB
Copying
- Max Copying Speed
- Up to 23 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Memory Sort
Printing
- Up to 23 ppm
- Printer Drivers / Emulations
- UFRII LT
- First Print Out Time B/W
- 6 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Max Original Size
- 216 mm width
- Original Type
- Sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm), 76.2 x 210 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Paper cassette - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m²
- Speed Details
- Printing: up to 23 ppm (A4) - B/W , Copying: up to 23 ppm (A4) - B/W , Scanning: 3 sec - B/W (300 dpi) , Scanning: 4 sec - colour (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- Linux, MS Windows 7, MS Windows Vista, Windows 8, Windows 8.1, Apple Mac OS X 10.6 or later, Windows 10
- Software Included
- Drivers & Utilities, Presto! PageManager
- Voltage Required
- 1120 Watt
- Power Consumption Standby
- 4.2 Watt
- Power Consumption Sleep
- 1.2 Watt
- First Copy Out Time B/W
- 9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 900 pages
- ISO 7779, ISO/IEC 19752, ISO 9296
- ENERGY STAR Certified
- 39 cm
- 37.1 cm
- 31.2 cm
- 10.1 kg
- Sound Emission
- 51 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
