Canon i-SENSYS MF229dw is a powerful and versatile mono laser Wi-Fi All-In-One with mobile and network connectivity for demanding small office environments. Be more productive with fast 2-sided scanning, copying and printing.
Powerful, connected All-In-One
This compact and stylish All-In-One offers the convenience of a professional quality printer, scanner, copier and fax in one space saving device. Its productivity boosting features can be shared seamlessly via your office network, Wi-Fi or smart device – making it the ideal choice to increase the efficiency of any busy office. -
Fast printing and copying
There’s no waiting for documents thanks to a fast A4 mono laser print and copy speed of 27ppm and a Quick First Print even from sleep mode. -
Business quality results
A combination of high print quality and Canon’s EF toner delivers impressive documents with sharp text and smooth grayscale graphics. Enhanced color scanning captures every detail from originals. Send scans to any PC with network scanning. -
Efficient 2-sided printing and scanning
Multi-page scanning and copying is quick and efficient thanks to an integrated 50-sheet 2-sided ADF. Scan double sided documents with ease and save money on paper with 2-sided printing. -
Quick, simple, quiet operation
Quick and simple to operate, the i-SENSYS MF229dw has a versatile, tilting display panel with a large touch screen LCD. The panel can be set vertically or placed facing upwards to suit the way you work. Efficient scanning and copying workflows are simple to set up using the quick one-touch solution keys. For operation in a quiet environment, Quiet Mode ensures less noisy printing so you can work without distracting others. -
Market leading energy efficiency
Canon’s On-Demand fixing technology ensures virtually no warm up time and helps cut energy consumption without affecting performance. With a class leading TEC rating, this device consumes as little as 1.7 Watts in sleep mode. -
All-in-One cartridge
Easily recyclable All-in-One cartridges combine toner, drum and cleaning units to reduce maintenance, increase reliability and minimize consumables.
- Canon i-SENSYS MF229dw - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 10000 pages
- Max Copying Speed
- Up to 27 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 27 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 127 x 140 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- Power
- AC 230 V (50/60Hz)
- 39 cm x 44.8 cm x 36 cm
- 13.1 kg
- Fax Type
- Plain paper
- Laser - monochrome
- 10000 pages
- Display
- 6 lines
- Display Features
- Touch screen
- Interface
- Standard Memory
- 256 MB
Copying
- Max Copying Speed
- Up to 27 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy
Printing
- Up to 27 ppm
- Printer Drivers / Emulations
- UFRII LT
- Image Enhancement Technology
- Automatic Image Refinement
- First Print Out Time B/W
- 6 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 256 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 4 station(s)
- Speed Dialing
- 104 station(s)
- Broadcast Transmission
- 114 stations
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, fax activity reports
Document & Media Handling
- Min Original Size
- 127 x 140 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets , ADF - 50 sheets size: 127 x 140 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 27 ppm (A4) - B/W , Copying: up to 27 ppm (A4) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Operating System Support
- MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2
- Software Included
- Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
- Voltage Required
- 1300 Watt
- Power Consumption Standby
- 5.8 Watt
- Power Consumption Sleep
- 1.7 Watt
- First Copy Out Time B/W
- 9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1700 pages
- 39 cm
- 44.8 cm
- 36 cm
- 13.1 kg
- Sound Emission
- 43 dB (idle) / 51 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.68 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.87 |
