Canon i-SENSYS MF229dw A4 Mono Laser Multifunction Printer
Quicklinx: 9TLMWS00 Mfr#: 9540B070
Canon i-SENSYS MF229dw is a powerful and versatile mono laser Wi-Fi All-In-One with mobile and network connectivity for demanding small office environments. Be more productive with fast 2-sided scanning, copying and printing.
  • Powerful, connected All-In-One
    This compact and stylish All-In-One offers the convenience of a professional quality printer, scanner, copier and fax in one space saving device. Its productivity boosting features can be shared seamlessly via your office network, Wi-Fi or smart device – making it the ideal choice to increase the efficiency of any busy office.
  • Fast printing and copying
    There’s no waiting for documents thanks to a fast A4 mono laser print and copy speed of 27ppm and a Quick First Print even from sleep mode.
  • Business quality results
    A combination of high print quality and Canon’s EF toner delivers impressive documents with sharp text and smooth grayscale graphics. Enhanced color scanning captures every detail from originals. Send scans to any PC with network scanning.
  • Efficient 2-sided printing and scanning
    Multi-page scanning and copying is quick and efficient thanks to an integrated 50-sheet 2-sided ADF. Scan double sided documents with ease and save money on paper with 2-sided printing.
  • Quick, simple, quiet operation
    Quick and simple to operate, the i-SENSYS MF229dw has a versatile, tilting display panel with a large touch screen LCD. The panel can be set vertically or placed facing upwards to suit the way you work. Efficient scanning and copying workflows are simple to set up using the quick one-touch solution keys. For operation in a quiet environment, Quiet Mode ensures less noisy printing so you can work without distracting others.
  • Market leading energy efficiency
    Canon’s On-Demand fixing technology ensures virtually no warm up time and helps cut energy consumption without affecting performance. With a class leading TEC rating, this device consumes as little as 1.7 Watts in sleep mode.
  • All-in-One cartridge
    Easily recyclable All-in-One cartridges combine toner, drum and cleaning units to reduce maintenance, increase reliability and minimize consumables.
Canon i-SENSYS MF229dw - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
10000 pages
Max Copying Speed
Up to 27 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 27 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
Scanning
600 x 600 dpi
Original Size
127 x 140 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AC 230 V (50/60Hz)
39 cm x 44.8 cm x 36 cm
13.1 kg
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 pages
Display
6 lines
Display Features
Touch screen
Standard Memory
256 MB
Copying
Max Copying Speed
Up to 27 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Up to 27 ppm
Printer Drivers / Emulations
UFRII LT
Image Enhancement Technology
Automatic Image Refinement
Automatic Duplexing
First Print Out Time B/W
6 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 256 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
4 station(s)
Speed Dialing
104 station(s)
Broadcast Transmission
114 stations
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, fax activity reports
Document & Media Handling
Min Original Size
127 x 140 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets , ADF - 50 sheets size: 127 x 140 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 27 ppm (A4) - B/W , Copying: up to 27 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2
Software Included
Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
AC 230 V (50/60Hz)
1300 Watt
Power Consumption Standby
5.8 Watt
Power Consumption Sleep
1.7 Watt
First Copy Out Time B/W
9 sec
Consumables Included
1 x toner cartridge (black) - up to 1700 pages
39 cm
44.8 cm
36 cm
13.1 kg
Sound Emission
43 dB (idle) / 51 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
9TLM C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
9TLM C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
