Canon i-SENSYS MF217w Mono Multifunction Laser Printer
Quicklinx: BJZBWS00 Mfr#: 9540B088
Productive Wi-Fi network and mobile ready mono laser All-In-One Wi-Fi, network and mobile ready, this mono laser. All-In-One offers seamless access from around the office. Packed with features to boost productivity, it's quick, easy-to-use and energy efficient.
  • Productive, connected All-In-One for small offices
    Stylish and well-connected this high-speed All-In-One mono laser printer offers print, copy, scan and fax functions in one compact space saving device. With Wi-Fi, Ethernet and mobile connectivity for easy sharing of functions, plus professional print quality and easy touch screen operation, it's the perfect desktop solution for small offices.
  • Wi-Fi for seamless sharing
    Connect seamlessly the way you want using this Wi-Fi, network and mobile ready device. Built-in Apple AirPrint and Mopria printing support automatically detects the printer for printing documents direct from the iPhone or iPad and Mopria certified devices. The free Canon Mobile Printing app also prints wirelessly to the printer from your Apple iOS or Android device.
  • Fast printing and copying
    There's no waiting by the machine for documents to output, thanks to a fast A4 mono laser print and copy speed of 23ppm and a Quick First-Print even from sleep mode. Multi-page printing, scanning and copying is effortless thanks to a 250-sheet paper cassette and an integrated 35-sheet ADF.
  • Business quality results
    A combination of print quality up to 1200 x1200 dpi and Canon's EF toner delivers professional prints and copies with sharp crisp text. Enhanced color scanning of up to 9600x9600 dpi captures every detail from originals. Send scans to any PC with network scanning.
  • Quick, simple operation
    Quick and simple to operate, the i-SENSYS MF217w has a versatile, tilting display panel with a large touch screen LCD. The panel can be set vertically or placed facing upwards to suit the way you work. Efficient scanning and copying workflows are simple to set up using the quick one-touch solution keys.
  • Energy efficient
    Canon's On-Demand fixing technology ensures virtually no warm up time and helps cut energy consumption without affecting performance. With a class leading TEC rating, this device consumes as little as 1.6 Watts in sleep mode.
  • Quiet Mode
    For operation in a quiet environment, Quiet Mode ensures less noisy printing so you can work without distracting others.
  • All-in-One cartridge
    Easily recyclable All-in-One cartridges combine toner, drum and cleaning units to reduce maintenance, increase reliability and minimize consumables.
Canon i-SENSYS MF217w - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Max Copying Speed
Up to 23 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 23 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
Scanning
600 x 600 dpi
Original Size
105 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
AC 230 V (50/60Hz)
39 cm x 44.1 cm x 36 cm
11.5 kg
Fax Type
Plain paper
Printing Technology
Laser - monochrome
8000 pages
Display
6 lines
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Copying
Max Copying Speed
Up to 23 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Up to 23 ppm
Printer Drivers / Emulations
UFRII LT
Image Enhancement Technology
Automatic Image Refinement
First Print Out Time B/W
6 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 256 pages
PC Faxing
Yes (send only)
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
4 station(s)
Speed Dialing
104 station(s)
Telephone / Fax Switch
Broadcast Transmission
114 stations
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, fax activity reports
Document & Media Handling
Min Original Size
105 x 148 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
100 sheets
Input tray - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets , ADF - 35 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 23 ppm (A4) - B/W , Copying: up to 23 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2
Software Included
Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
AC 230 V (50/60Hz)
1270 Watt
Power Consumption Standby
5.4 Watt
Power Consumption Sleep
1.6 Watt
First Copy Out Time B/W
9 sec
Consumables Included
1 x toner cartridge (black) - up to 1700 pages
39 cm
44.1 cm
36 cm
11.5 kg
Sound Emission
43 dB (idle) / 50 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
