Canon i-SENSYS MF211 Mono Multifunction Laser Printer
Quicklinx: BJZFWS00 Mfr#: 9540B108
Canon i-SENSYS MF211 is Fast and efficient mono laser 3-in-1 offering print, copy and scan functions in one convenient, compact device. Operation is easy thanks to a tilting control panel and one-touch solution keys.
  • Space-saving 3-in-1
    Stylish and compact this high-speed multifunctional mono laser printer offers print, copy and scan functions in one space-saving device. With professional print quality and easy operation, it’s the perfect desktop solution for small or home offices.
  • Fast printing and copying
    There’s no waiting by the machine for documents to output, thanks to a fast A4 mono laser print and copy speed of 23ppm and a Quick First Print Out Time from sleep mode.
  • Business quality results
    A combination of print quality up to 1200 x1200 dpi and Canon’s EF toner delivers professional prints and copies with sharp crisp text and smooth graphics. Enhanced color scanning of up to 9600x9600 dpi captures every detail.
  • Quick, simple operation
    Quick and simple to operate, the i-SENSYS MF211 has a versatile, tilting display panel with a 5 line LCD, which shows you the information you need at a glance. The panel can be set vertically or placed facing upwards to suit the way you work. Efficient scanning and copying workflows are simple to set up using the quick one-touch solution keys, so it’s easy to send scans to file or save paper by copying several images to one sheet.
  • Energy efficient
    Canon’s On-Demand fixing technology ensures virtually no warm up time and helps cut energy consumption without affecting performance. With a class leading TEC rating, this device consumes just 1.6 Watts in sleep mode.
  • Quiet mode
    This multifunctional is silent in standby mode, while for operation in a quiet environment, Quiet Mode ensures less noisy printing - so you can work without distracting others.
  • All-in-One cartridge
    Easily recyclable All-in-One cartridges combine toner, drum and cleaning units to reduce maintenance, increase reliability and minimize consumables.
Canon i-SENSYS MF211 - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Max Copying Speed
Up to 23 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 23 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Original Size
216 mm width (max)
Original Type
Sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0
AC 230 V (50/60Hz)
39 cm x 44.1 cm x 31.2 cm
10.1 kg
Printing Technology
Laser - monochrome
8000 pages
Display
5 lines
USB 2.0
Standard Memory
128 MB
Copying
Max Copying Speed
Up to 23 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Up to 23 ppm
Printer Drivers / Emulations
UFRII LT
Image Enhancement Technology
Automatic Image Refinement
First Print Out Time B/W
6 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 mm width
Original Type
Sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
100 sheets
Input tray - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 23 ppm (A4) - B/W , Copying: up to 23 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows XP, Linux, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.5.8 or later, Windows 8, Windows 8.1
Software Included
Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
AC 230 V (50/60Hz)
1270 Watt
Power Consumption Standby
3.2 Watt
Power Consumption Sleep
1.6 Watt
First Copy Out Time B/W
9 sec
Consumables Included
1 x toner cartridge (black) - up to 1700 pages
39 cm
44.1 cm
31.2 cm
10.1 kg
Sound Emission
43 dB (idle) / 50 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
