Canon i-SENSYS MF211 is Fast and efficient mono laser 3-in-1 offering print, copy and scan functions in one convenient, compact device. Operation is easy thanks to a tilting control panel and one-touch solution keys.
Space-saving 3-in-1
Stylish and compact this high-speed multifunctional mono laser printer offers print, copy and scan functions in one space-saving device. With professional print quality and easy operation, it’s the perfect desktop solution for small or home offices. -
Fast printing and copying
There’s no waiting by the machine for documents to output, thanks to a fast A4 mono laser print and copy speed of 23ppm and a Quick First Print Out Time from sleep mode. -
Business quality results
A combination of print quality up to 1200 x1200 dpi and Canon’s EF toner delivers professional prints and copies with sharp crisp text and smooth graphics. Enhanced color scanning of up to 9600x9600 dpi captures every detail. -
Quick, simple operation
Quick and simple to operate, the i-SENSYS MF211 has a versatile, tilting display panel with a 5 line LCD, which shows you the information you need at a glance. The panel can be set vertically or placed facing upwards to suit the way you work. Efficient scanning and copying workflows are simple to set up using the quick one-touch solution keys, so it’s easy to send scans to file or save paper by copying several images to one sheet. -
Energy efficient
Canon’s On-Demand fixing technology ensures virtually no warm up time and helps cut energy consumption without affecting performance. With a class leading TEC rating, this device consumes just 1.6 Watts in sleep mode. -
Quiet mode
This multifunctional is silent in standby mode, while for operation in a quiet environment, Quiet Mode ensures less noisy printing - so you can work without distracting others. -
All-in-One cartridge
Easily recyclable All-in-One cartridges combine toner, drum and cleaning units to reduce maintenance, increase reliability and minimize consumables.
- Canon i-SENSYS MF211 - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 8000 pages
- Max Copying Speed
- Up to 23 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 23 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 216 mm width (max)
- Original Type
- Sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0
- Power
- AC 230 V (50/60Hz)
- 39 cm x 44.1 cm x 31.2 cm
- 10.1 kg
- Laser - monochrome
- 8000 pages
- Display
- 5 lines
- Interface
- USB 2.0
- Standard Memory
- 128 MB
Copying
- Max Copying Speed
- Up to 23 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy
Printing
- Up to 23 ppm
- Printer Drivers / Emulations
- UFRII LT
- Image Enhancement Technology
- Automatic Image Refinement
- First Print Out Time B/W
- 6 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 mm width
- Original Type
- Sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 100 sheets
- Input tray - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 23 ppm (A4) - B/W , Copying: up to 23 ppm (A4) - B/W
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows XP, Linux, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.5.8 or later, Windows 8, Windows 8.1
- Software Included
- Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
- Voltage Required
- 1270 Watt
- Power Consumption Standby
- 3.2 Watt
- Power Consumption Sleep
- 1.6 Watt
- First Copy Out Time B/W
- 9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1700 pages
- 39 cm
- 44.1 cm
- 31.2 cm
- 10.1 kg
- Sound Emission
- 43 dB (idle) / 50 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
