With fast, high-quality color laser printing and flexible configuration options to provide a large paper capacity, this compact printer lets your workplace be even more productive.
Benefits
- Rapid colour printing at 38ppm
- Increased productivity delivered by an expandable page capacity to 2,300 with optional paper cassettes and configuration options
- Suitable for a variety of environments thanks to its small footprint
- Print from smartphones and tablets with support for mobile printing
- Efficient to run, with higher capacity Genuine Canon toner cartridges
- New high performance S Toner for faster, energy efficient printing
- Auto toner seal removal for easier cartridge installation
- Simple to manage as part of your network
- Optional secure printing and storage
- Easy double-sided printing to reduce costs and waste
Fast and flexible printing-
With full colour printing at 38ppm, the LBP712Cx is ideal for busy working environments that demand a reliable, versatile printer. The ability to have up to 4 high-capacity paper feeder cassettes makes it perfect for the modern connected workplace.
High-capacity in a small footprint-
To be productive, you need a high-capacity printer, so that’s why the LBP712Cx has a large 650-page capacity as standard, expandable to 2,300 pages. A compact and capable office companion, this larger capacity still comes in a small package. Whatever the printing task, the LBP712Cxis built for versatility. From A5 to A4 double-sided documents, it’s ready to deliver in seconds.
Working on the go-
Thanks to the LBP712Cx’s support for Apple AirPrint (iOS) and Mopria (Android), you can print easily from any compatible device. You can also benefit from more advanced features with the Canon PRINT Business app. For those using Google in the workplace, the LBP712Cx comes Google Cloud print-ready for seamless integration.
Higher capacity toner cartridges-
Canon has redesigned its toner cartridges to be better than ever. The toner seal inside the cartridge is now automatically removed when the cartridge is fitted, cutting down on waste and installation time. In the same compact size, the new Genuine Canon toner cartridges now have a higher capacity, letting you be even more productive.
Canon’s exceptional image quality-
Whether you are printing presentations for important meetings or brochures to share with customers, the LBP712Cx produces superior colour graphics, images and text in laser quality prints to make a greater impact on the reader. Canon’s renowned image expertise ensures that businesses of any size can produce professional looking documents with fine lines, crisp text and high resolution – creating the positive impression modern businesses want to make.
Smart networking capabilities-
The LBP712Cx is a superbly versatile addition to your printer fleet. Support for PCL5e/6 and Adobe PostScript printer languages enable hassle-free integration into managed network environments. The LBP712Cx is equally well-suited to managed print service environments and is compatible with Canon’s e-Maintenance remote service management system The LBP712Cx can also be integrated into Canon’s uniFLOW output management platform, bringing you the efficiency and security of My Print Anywhere plus the added benefits of accounting and cost recovery.
With full color printing at 38 ppm, the LBP712Cx is ideal for busy working environments that demand a reliable, versatile printer. The ability to have up to 4 high-capacity paper feeder cassettes makes it perfect for the modern connected workplace. -
To be productive, you need a high-capacity printer, so that's why the LBP712Cx has a large 650-page capacity as standard, expandable to 2,300 pages. A compact and capable office companion, this larger capacity still comes in a small package. Whatever the printing task, the LBP712Cxis built for versatility. From A5 to A4 double-sided documents, it's ready to deliver in seconds. -
Canon's amazing image quality
Whether you are printing presentations for important meetings or brochures to share with customers, the LBP712Cx produces superior color graphics, images and text in laser quality prints to make a greater impact on the reader. Canon's renowned image expertise ensures that businesses of any size can produce professional looking documents with fine lines, crisp text and high resolution - creating the positive impression modern businesses want to make.
- Canon i-SENSYS LBP712Cx - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 28.8 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 38 ppm - colour - A4 (210 x 297 mm) , Up to 38 ipm - colour duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 9600 x 600 dpi
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PCL 5C, PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF
- Media Type
- Envelopes, labels, plain paper, heavy-weight paper, cards, recycled paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet paper cassette
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Networking
- Print server
- Power
- AC 230V
- System Requirements
- Linux, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Android, Apple MacOS X 10.6.8 or later, Windows 8, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10
- 45.8 cm x 46.4 cm x 38.8 cm
- 2 Years
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 9600 x 600 dpi
- 9600 x 600 dpi
- First Print Out Time B/W
- 5.1 sec
- First Print Out Time Colour
- 6 sec
- Fonts Included
- 93 x PCL , 136 x PostScript
- Media Handling
RAM
- 1 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 216 x 297 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Foolscap (216 x 343 mm), 101.6 x 148 mm
- Media Weight
- 60 g/m² - 216 g/m²
- 650 sheets
- Media Feeders
- 1 x automatic - 550 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 216 g/m²
- Max Media Capacity
- 2300 sheets
- Output Trays Capacity
- 200 sheets
Duty Cycle
- 80000 pages
- 2000 - 7500 pages
- Networking
- Print server
- Secure Print
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - Canon 040 , 1 x toner cartridge (cyan) - Canon 040 , 1 x toner cartridge (magenta) - Canon 040 , 1 x toner cartridge (yellow) - Canon 040
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 1470 Watt
- Power Consumption Stand by
- 34 Watt
- Power Consumption Sleep
- 1.3 Watt
- Software Included
- Drivers & Utilities, Canon PRINT Business
- OS Required
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 36 dB
- Sound Emission (Operating)
- 51 dB
- 45.8 cm
- 46.4 cm
- 38.8 cm
- 28.8 kg
Service and Support
- 2 Years
