The natural choice for small businesses who demand the finest quality in print. This compact A4 laser printer offers up to 14 ppm in both color and black and white. With built-in Wi-Fi, it's the ideal choice for small businesses who want consistent, high-quality results.
Produce consistently superb print
Small offices and workgroups can produce professional-quality A4 color laser printouts. Featuring 1200 x 1200 dpi print resolution, the LBP7110Cw is ideal for creating high quality full-color sales and marketing assets or documents containing fine graphics and detailed text. With the LBP7110Cw, it's easy to deliver consistently impressive results without the cost of outsourcing important print jobs. -
Compact, convenient design
The LBP7110Cw's sleek, low profile form blends easily into business environments. A small footprint means this desktop printer fits where space is at a premium. With its contemporary design and quiet operation it can be placed in customer-facing environments. -
Network and Wi-Fi enabled for easier sharing
The LBP7110Cw is tailor made for personal use or for sharing its productive capabilities within small workgroups, thanks to its network interface. The Remote User Interface (RUI) lets users and administrators monitor and manage machine status from their browsers. The LBP7110Cw has built-in Wi-Fi, for effortless connection to a wireless network without intrusive and restrictive cabling. -
Save time and achieve more productivity
14 ppm output in both mono and color helps you complete important or time-sensitive tasks more quickly. Canon's Quick First-Print technology improves response time from sleep mode, so you won't waste valuable time waiting for your printer to warm up. A 150-sheet cassette minimizes replenishment times so your workflows stay fluid and productive. -
Easy to manage and maintain
The all-in-one cartridge system reduces maintenance and provides continuous high quality output. A higher yield black toner cartridge is available for even less downtime. Simply replace the cartridge - containing toner, drum and cleaning units - and the printer is virtually as good as new. Convenient front loading enables easy, quick and clean cartridge replacement. -
The cost-effective, energy-efficient choice
The LBP7110Cw uses only 0.9 watts in sleep mode. It is ENERGY STAR certified and has a market-leading TEC (Typical Energy Consumption) rating, which helps you comply with your environmental and sustainability objectives as well as cost reduction targets.
- Canon i-SENSYS LBP7110Cw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- Form Factor
- Desktop
- 16.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 83 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 14 ppm - B/W - A4 (210 x 297 mm) , Up to 14 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (Colour)
- 1200 dpi
- Interface
- USB, LAN, Wi-Fi(n)
- RAM Installed (Max)
- 64 MB
- Language Simulation
- Canon Ultra Fast Rendering (UFRII)
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, glossy film, cards, coated paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray
- Monthly Duty Cycle (max)
- 30000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Linux, Apple MacOS X 10.5.x or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 40.6 cm x 45.4 cm x 25.5 cm
- Printer Type
- Form Factor
- Desktop
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 1200 dpi
- First Print Out Time B/W
- 18 sec
- First Print Out Time Colour
- 18 sec
- Media Handling
RAM
- 64 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 83 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Output Trays Capacity
- 125 sheets
Duty Cycle
- 30000 pages
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 800 pages - Canon 731 Starter , 1 x toner cartridge (cyan) - up to 800 pages - Canon 731 Starter , 1 x toner cartridge (magenta) - up to 800 pages - Canon 731 Starter , 1 x toner cartridge (yellow) - up to 800 pages - Canon 731 Starter
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 800 Watt
- Power Consumption Stand by / Sleep
- 10 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 49 dBA
- 40.6 cm
- 45.4 cm
- 25.5 cm
- 16.6 kg
Canon 731 Cyan Cartridge | In Stock | £56.74 |
Canon 731 Yellow Cartridge | In Stock | £53.26 |
Canon 731 Magenta Cartridge | In Stock | £53.26 |
Canon 731 Standard Cap Black Cart | In Stock | £48.04 |
Canon 731 High Cap Black Cartridge | In Stock | £62.68 |
