The LBP663Cdw is an ultra-fast, highly accurate, single-function color laser printer with features designed to enhance workflow in small and medium offices.
Compact in size, this highly accurate printer is perfect for the small to medium-sized businesses. A single-function colour laser printer, it boasts several useful features to boost productivity including fast output of up to 27 single-sided A4 pages per minute. Automatic double-sided printing ensures paper costs are kept to a minimum, and the Secure PIN option adds another level of security. Connect your mobile device to the printer using the Canon PRINT business app.
Efficient connectivity
With options like Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi, alongside mobile printing capabilities through Apple AirPrint, Google Cloud Print, and Mopria Print Service, this printer offers versatile connectivity solutions for any office environment. -
High-quality printing
Achieve professional-grade prints with a maximum resolution of 1200 x 1200 DPI for both black and white and color documents, ensuring crisp and clear output every time. -
Robust media handling
Catering to a wide range of media sizes from A4 to Legal, and types including envelopes, glossy paper, and labels, the Canon i-SENSYS LBP663Cdw is equipped to handle diverse printing needs. With a 300-sheet total media capacity, it efficiently manages large print jobs. -
Secure and reliable
Featuring Secure Print to protect confidential documents and a monthly duty cycle of up to 50,000 pages, this printer is designed for reliability and security in busy work environments. -
Eco-friendly operation
With a sound emission as low as 28 dB in idle mode and energy-efficient power consumption, this printer operates quietly and sustainably, minimizing its impact on the office environment.
- Canon i-SENSYS LBP663Cdw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 20.7 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 355.6 mm
- Print Speed
- Up to 27 ppm - B/W - A4 (210 x 297 mm) , Up to 24.5 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 27 ppm - colour - A4 (210 x 297 mm) , Up to 24.5 ipm - colour duplex - A4 (210 x 297 mm) , Up to 49 ppm - B/W - A5 (148 x 210 mm) , Up to 49 ppm - colour - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG
- Media Type
- Envelopes, labels, plain paper, cards, recycled paper, thin paper, postcards, glossy paper, coloured paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 50-sheet multipurpose tray, 250-sheet paper cassette
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- Power
- AC 230V
- System Requirements
- Linux, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.9.5 or later, Apple macOS 10.14 or later
- 43.7 cm x 46.9 cm x 31.3 cm
- 2-year Limited Warranty
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- First Print Out Time B/W
- 7.7 sec
- First Print Out Time Colour
- 8.6 sec
- Fonts Included
- 45 x PCL , 136 x PostScript
- Media Handling
RAM
- 1 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 355.6 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 148 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 300 sheets
- Media Feeders
- Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Multi-purpose tray: 1 - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Output tray: 1 - 150 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 50000 pages
- 750 - 4000 pages
- Networking
- Print server
- Secure Print
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages - Canon 055 Starter , 1 x toner cartridge (cyan) - up to 1200 pages - Canon 055 Starter , 1 x toner cartridge (magenta) - up to 1200 pages - Canon 055 Starter , 1 x toner cartridge (yellow) - up to 1200 pages - Canon 055 Starter
- Power Device
- Power supply
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 1380 Watt
- Power Consumption Stand by
- 17 Watt
- Power Consumption Sleep
- 0.6 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 28 dB
- Sound Emission (Operating)
- 48 dB
- 43.7 cm
- 46.9 cm
- 31.3 cm
- 20.7 kg
Canon 055H High Yield Ink Cartridge - Yellow | In Stock | £150.23 |
Canon 055H High Yield Ink Cartridge - Magenta | In Stock | £150.23 |
Canon 055H High Yield Ink Cartridge - Cyan | In Stock | £150.23 |
Canon 055H High Yield Ink Cartridge - Black | In Stock | £109.27 |
